383 vs 350?
Old Mar 10, 2010 | 03:57 PM
MakoShark72's Avatar
MakoShark72
Default 383 vs 350?
Is the only BASIC difference in a 383 vs a 350 the crank (longer stroke)?? And associated clearance issues...
Thanks.
Old Mar 10, 2010 | 03:59 PM
BKbroiler's Avatar
BKbroiler
.030 overbore on the 350, in addition to the stroke increase.
Old Mar 10, 2010 | 04:05 PM
Gordonm's Avatar
Gordonm
Pistons will be different also. The same rods can be used. Clearance must be checked. I had to do a fair amount of grinding on a 350 block I had.
Old Mar 10, 2010 | 05:02 PM
enrgizerbunny's Avatar
enrgizerbunny
I found this to very very informative about 383's
http://www.carcraft.com/techarticles...evy/index.html
The stock rods can be used, but using the original rods causes the piston to push on the cylinder wall much more than it previously had.
I'm looking to build me a stroker down the road one day and then find a body to match.
Last edited by enrgizerbunny; Mar 10, 2010 at 05:08 PM. Reason: Put the link in the wrong place
Old Mar 10, 2010 | 05:57 PM
schmegeggie's Avatar
schmegeggie
Lots more HP too!
Old Mar 10, 2010 | 07:48 PM
jordan89's Avatar
jordan89
Originally Posted by schmegeggie
Lots more HP too!
Don't forget, lots more torque as well.
Old Mar 10, 2010 | 08:31 PM
Ganey's Avatar
Ganey
& can run like a BB.
Old Mar 10, 2010 | 08:50 PM
ToddG's Avatar
ToddG
The biggest difference is the cylinder dwell time at TDC. This factor in its self creates more torque. Not to say this longer dwell time produces all the new found torque as there are quite a few other factors that contribute to it. On a scale I would say this is one of the largest reasons.
c-ya
ToddG
Here is one of the better explanations...
http://blogs.myspace.com/index.cfm?f...ogId=444808009
Old Mar 10, 2010 | 09:08 PM
larryg3's Avatar
larryg3
great link Todd that really explains the stroker engine quite well.
Old Mar 10, 2010 | 11:36 PM
eagle275's Avatar
eagle275
Default .
To 383 vs 350?
