Need help going from 3 pulleys to 2...
Old Mar 10, 2002 | 11:00 PM
Corellian Corvette's Avatar
Corellian Corvette
Default Need help going from 3 pulleys to 2...
Is there such a thing as a fan or water pump pulley "spacer"?
For a long time I noticed that I have three pulley grooves coming off my water pump even though my system only uses 1 (for the alternator). I guess the others are for AC and for the AIR system (which I no longer have)
Figured that I might get rid of one and save some rotating weight.
As it turns out, the system includes a long "double" pulley and a shorter single pulley in front. I wanted to just remove the front pulley since I don't need it, but the fan/clutch won't sit against the other pulley flush -- it hits the nub of the water pump.
Anyway, wondering if anyone has encountered this before, and if there is some sort of spacer I could put between the pulley and the fan so it will sit flush. I only need about 1/8th of an inch!
Thanks!
Old Mar 11, 2002 | 02:14 PM
Corellian Corvette
Default Re: Need help going from 3 pulleys to 2... (Corellian Corvette)
Anyone?
Old Mar 11, 2002 | 02:19 PM
xfactor974's Avatar
xfactor974
I believe that you can get an idler pully for the system your looking to build. But to tell you the truth, I'm not sure where to get one.
To Need help going from 3 pulleys to 2...
