68 door panel help
Old Mar 11, 2002 | 01:02 PM
Black68Vette's Avatar
Black68Vette
Default 68 door panel help
I just got my new (well new to me) door panels delivered. My car is a hack job inside, someone gutted all the 68 stuff, and replaced it with 77. :U
Anyhow, does anything go into the hard plastic inserts? or does that just mount directly to the door frame and thats how you close the door?
Thanks!
Old Mar 11, 2002 | 02:20 PM
MELVIN's Avatar
MELVIN
Default Re: 68 door panel help (Black68Vette)
Early production 68's had the plastic pull insert only. Later 68's had a pull door handle, like the 69's. So you would have to determine if you have an early or late 68.
Im not sure what seq number it was when they started putting pull door handles on like the 69's
Old Mar 11, 2002 | 02:27 PM
Garys '68's Avatar
Garys '68
I assume you mean the plastic insert grab "slot" in the door (no external handle on the 68s).
If so, there's supposed to be a metal strip between the plastic insert and the door frame. It may be integrated into the door panel.
I'm putting mine back together now. I think I'll add an aluminum strip and a couple fender washers insde the plastic handle insert. I understand that this was discontinued because the plasic handle would pull loose and crack the door panel at the ends.
Gary
Old Mar 11, 2002 | 02:57 PM
R1234's Avatar
R1234
Default Re: 68 door panel help (Garys '68)
My original door panels have the metal strip behind the plastic grab handle, embedded into the door panel. I can't tell whats behind the plastic grab handle on my new repo's. If I had to guess, I would guess no metal insert.
The exterior grab handles came after serial number 19,533. This is according to the 68-69 NCRS judging manual.
Old Mar 11, 2002 | 03:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It is my understanding all '68 door panels have the metal "finger tip" inserts in the panel which are used to close the door. Two large sheet metal screws go through these and into the steel door shell. Some '68s (mine included) also have a large plastic door pull handle above the insert which also assists with closing the door. These pull handles are '68 only and much larger than the '69 -up pulls.
Old Mar 11, 2002 | 03:07 PM
Black68Vette
Default Re: 68 door panel help (68rdstr)
Ah so then I am in luck (not like my car will ever reach NCRS standards anyhow). No handle for me on the new-used panels. Its a real PITA to try and restore a 68 reasonably correctly on a low budget after the whole interior was bubbafied...
Old Mar 11, 2002 | 03:14 PM
R1234's Avatar
R1234
Default Re: 68 door panel help (Easy Mike)
Hello MIke,
The original door panels on my 68 had plastic finger tip inserts with the metal strip located underneath, then the door panel fiberboard. All this is attached with two screws that screw into clips attached to the door shell.
Old Mar 11, 2002 | 03:23 PM
Black68Vette
Hmm, what sorta clips are they? I'm going to be removing 77 door panels to put the 68s on, so I am sure the clips have low odds of still sticking to the door shell. Any help you can give I appreciate!
Old Mar 11, 2002 | 03:35 PM
R1234's Avatar
R1234
There like j-clips. They fit over a hole in the door shell. I think its a number 8
pan head interior screw with a washer. There are two.
[Modified by 68rdstr, 1:36 PM 3/11/2002]
Old Mar 11, 2002 | 04:34 PM
verskel's Avatar
verskel
Just a check, but you do have the correct 'push' button doors, right ?
My door panels on my early '68 <#6948> :chevy
don't 'fit' quite right on the doors and I'm suffering from previous owners replacing parts with '69 stuff which is a pain in the %$#! :mad
Let us know how your project works out - wish I could see your vette in person ! :D
Old Mar 11, 2002 | 05:24 PM
Black68Vette
Default Re: 68 door panel help (verskel)
Push button doors, all red taillights, little rectangular backup lights... All the external stuff is right, but all the interior is from 77... Nightmarish for sure. I have an "Unleaded Fuel Only" gas gauge :p:
If you want to cry a little, I can post some interior pics... Luckily i've managed to get a 68 console plate, 68 gauge panel, A/C outlet and most of the rest of the stuff... haven't gotten to replacing it yet, as I want to do it all at once.
Mine's from a little later in 68 than yours, around mid February.... Need to get me some 68 seats at a reasonable price.. sigh....
But as an interesting tidbit, I have a solid rear valance panel (no exhaust cutouts) with the correct reverse lights... that had undercar exhaust still just stuck under it, with the pipes stuck out under the valance panel... Well, I just had to go and put the sidepipes on ;) :cheers:
[Modified by Black68Vette, 9:28 PM 3/11/2002]
[Modified by Black68Vette, 9:30 PM 3/11/2002]
Old Mar 11, 2002 | 05:39 PM
R1234's Avatar
R1234
Lucky You, I'm still looking for a 68 only AC wiper switch plate.
Old Mar 11, 2002 | 05:44 PM
Black68Vette
Whats the difference (like I really want to know now, i'm sure what I have is the 69-77) from the 68 to the 69-77 plate? I can post a pic of the one I got.. It was brand spanking new NOs, in the GM box. Got it off ebay about 6 months ago, the seller had found a whole box of these in the back of a warehouse (he had 6 or 7 I think)
Old Mar 11, 2002 | 05:51 PM
R1234's Avatar
R1234
The 68 has a single skinny air deflector mounted in the center ac distribution duct. The wiper switch plate fits around it
The 69 and up have 2 deflectors mounted in the wiper switch plate. The 69 and up also have a lever to open and close the air flow.
Old Mar 11, 2002 | 05:53 PM
Black68Vette
Yep, I got a 69.. oh well... i'm still just restoring to "1968 crappy driver condition" really, can't stand all the 77 stuff in her, don't have the money to buy it all new at once. Any good seat resources for a reasonable price anyone? Early 68 style....
Old Mar 11, 2002 | 06:23 PM
R1234's Avatar
R1234
That ever popular ebay has once in awhile. Maybe your lucky in one way. If your ac distribution duct is 69 and up. Your wiper plate should fit this ductwork. If you have the 68 duct work, it want fit. 68's ya gotta love'em.
Old Mar 11, 2002 | 06:47 PM
Black68Vette
Yeah, I think every 68 was a Friday night 4:55pm car somehow.. Sure seems that way.
And I think I got lucky, cause the vent fits ok with the 77 dash.. who knows, she may not have been an AC car back in 68... sigh, no bloomington gold for me!
To 68 door panel help
