Degreeing Cam and Adjustments
http://www.summitracing.com/parts/SUM-G6600-B/
In my initial go through I found my centerline to be 104 degrees and recommended centerline from comp cams is 106. So then I used the keyways on the crank timing sprocket to retard the cam my 2 degrees (using the marked keyways and new timing marks). I then reassembled everything aand went through the process again and found my centerline was now 104.5 degrees / maybe 5 degrees.
The instructions with the timing set read that the keyways / timing mark on the crank sprocket should properly adjust the cam (ie the 2 deg retard on the crank timing sprocket should have gotten me to a 106 deg centerline.
What is more likely? I messed up the process / measurements on the initial check? Or that the keyways dont indicate camshaft adv/ret?
I am going to run through the entire process again tonight but wanted to check in with the forum today and see if there was any helpful insight since I have never degreed a cam before.
For more background, here are my other recent posts on the buid-up:
http://forums.corvetteforum.com/c3-t...ild-issue.html
http://forums.corvetteforum.com/c3-t...tion-long.html
Shane
Shane
