Starter recommendation
Old Mar 15, 2010 | 10:14 AM
ssenay72's Avatar
ssenay72
Default Starter recommendation
I want to replace my starter while im at changing everything. Would like to get something decent without having fitment problems!!
Just want to bolt it in and not worry about it!
Should i go with one of these (little more pricey) or just get a generic replacement at advanced autoparts....
http://www.summitracing.com/parts/MSD-5095/
http://www.summitracing.com/parts/PWM-9500/
http://www.summitracing.com/parts/PWM-9000/
Old Mar 15, 2010 | 11:27 AM
MelWff's Avatar
MelWff
why dont you just have your current starter rebuilt locally?
Old Mar 15, 2010 | 12:24 PM
ssenay72's Avatar
ssenay72
How about I buy a better one. LOL
I don't do rebuilt stuff often, unless I have to. Plus i'm curious about something better.
motor is 1975 350. Any suggestions...
Old Mar 15, 2010 | 03:44 PM
MMH2009's Avatar
MMH2009
AC Delco from Ecklers!
Old Mar 15, 2010 | 04:13 PM
MelWff's Avatar
MelWff
if your not having starter problems what would be better than the original starter whether new or rebuilt? The others you listed may need shims to properly engage the starter. To the best of my knowledge they are not required for an original starter.
Old Mar 16, 2010 | 12:23 PM
ssenay72's Avatar
ssenay72
Someone much be using a high torque mini starter that bolts on nicely....anyone??
Old Mar 16, 2010 | 01:21 PM
Hornevette76's Avatar
Hornevette76
I just finished installing a Summit mini Monday, it fit without any trouble at all. Well worth the cost, alot more room with the headers. I could not believe how nice the mini's are. Car starts great now and no problems when it gets hot. Wish I had done it sooner. 76,350, A/T modified, 410 HP
Old Mar 16, 2010 | 01:34 PM
ssenay72's Avatar
ssenay72
what was the part number/model? (i have an a/t also)
How was the wiring?
Old Mar 16, 2010 | 07:09 PM
Hornevette76
http://www.summitracing.com/parts/SUM-829000
Check this one out, should be the same as 76, wiring was easy just follow your wires like the old starter was wired should be fine. If you have any trouble just shoot me a PM.
Old Mar 16, 2010 | 07:41 PM
BKbroiler's Avatar
BKbroiler
I'm using a Jeg's mini starter. Works fine, half the weight.
Old Mar 16, 2010 | 08:23 PM
drwet's Avatar
drwet
High torque gear reduction starters are available through your local parts store. Gm has been using them for years and they are vastly superior to the old ones our Corvettes originally came with, and about 20 lbs. lighter. The only variables are the bolt pattern - staggered or straight across, and the size of the flywheel/ring gear. My '79 uses a starter from a '96 full size Chevy truck. A little research and you'll find one to fit your car. As for shimming to align the starter, you should do that no matter what starter you use. Most guys don't bother, though. Not a problem unless its a problem
Old Mar 16, 2010 | 09:04 PM
C3 4ME's Avatar
C3 4ME
Another vote for rebuilding your exisitng one. I just had mine done, and it works better than ever. Even with headers, I've never had a problem with hot starts, and I do not run a heat sheild.
Old Mar 16, 2010 | 09:24 PM
willem wallace's Avatar
willem wallace
Default PMGR GM Starter
Bought a PMGR mini starter, GM part #10455709, from Bill Howard.
Shipped to my door, with correct grade 8 hardware: $135.00
Howard Enterprises-620-228-1477
Old Mar 16, 2010 | 09:45 PM
ssenay72's Avatar
ssenay72
Ok so I have a 75 with a 350 and I just looked under mine and my starter bolts are staggered....(assuming an inline won't work here) Why would your 76 be straight and mine offset?
Old Mar 16, 2010 | 10:41 PM
SteveG75's Avatar
SteveG75
Straight across bolts mean a 153 tooth flywheel (12-3/4" diameter), staggered bolts mean a 168 tooth flywheel (14" diameter).
For the 168 tooth flywheel, I like the GM geared starter off a 1990's vintage BB truck. The GM part number is 9000852.
One note with the 9000852. You cannot use your stock bolts. The correct bolts are special with metric shanks and standard threads. GM part# for the bolts is 12338064 and you can get them from any dealer.
Old Mar 17, 2010 | 12:32 AM
b71vette's Avatar
b71vette
Give Mean Green a call and tell them you need the GM Staggered Bolt Pattern Mini-starter, quality product. They told me they sell a lot of these to RV owners with 454 Big Blocks.
http://www.mean-green.com/
Go with the staggered bolt pattern even if the in-line will work, I think the staggered pattern provides a more rigid clamp load.
Old Mar 17, 2010 | 12:52 AM
71406's Avatar
71406
This is what I switch to. Got tired of the rebuilt units failing. And like suggested you will need the correct bolts if you go this route.
To Starter recommendation
Old Mar 17, 2010 | 12:42 PM
drwet's Avatar
drwet
That may be true for the Corvette, I don't know, but its not true for other GM products. The straight and diagonal bolt patterns were both used with the 153 tooth flywheel. I checked my notes and if you have a 153 tooth flywheel with the diagonal pattern, look up a starter for a 1996 full size Chev truck with the 5.7 motor (5.0 might be the same, I don't know). If you have a 153 tooth flywheel with the straight pattern, look up a starter for a 1996 Impala SS. These are both the small style gear reduction starters. They save about 20 lbs in weight, have far more torque than the old large style, and will start the car with a weak battery when the old style starters won't. They are also much easier to install because of their smaller size. I also like these starters better than the aftermarket ones because they have the snout that supports both sides of the starter gear. I don't know for sure that this makes any difference, but this design makes more sense to me.
Old Mar 17, 2010 | 06:26 PM
markdtn's Avatar
markdtn
I am using a C4 starter on mine. Starts every time.
Old Mar 17, 2010 | 06:44 PM
Ironcross's Avatar
Ironcross
A high torque OE style starter is your best bet from any quality rebuilder. Substitutes for GM starters are all right if you have a spare....
