Engine pops and back fires when going down hill...
Old Mar 11, 2002 | 03:31 PM
KJL's Avatar
KJL
Default Engine pops and back fires when going down hill...
I have a 72 L48 turbo 400 with headers going into 2 1/2" pipes and flow master mufflers. The cam is unknown. The car runs well with good off idle response and it idles well with a small lope. I noticed that if I am going down a hill and I am let the engne slow the car it pops and back fires a small bit. Is this normal?
Thanks!!
Old Mar 11, 2002 | 04:06 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Engine pops and back fires when going down hill... (KJL)
air is getting into the exhaust system causing the back fire. check for exhaust leaks by having someone hold a rag in the tail pipe and listen for a hissing sound at the joints and around the headers. :chevy
Old Mar 11, 2002 | 04:11 PM
vettesite's Avatar
vettesite
If not an exhaust leak, check that carb idle mixture not set to rich and the timing is set correctly.
[Modified by vettesite, 2:11 PM 3/11/2002]
Old Mar 11, 2002 | 04:18 PM
VETDRMS's Avatar
VETDRMS
heh, i have about the same setup, it does that, but only when i let off at higher RPM's, i'm pretty sure that is normal. ~enjoy
To Engine pops and back fires when going down hill...
