79 Headlight switch vacuum question
Old Mar 16, 2010 | 05:58 PM
ragtop00's Avatar
ragtop00
Default 79 Headlight switch vacuum question
I'm putting a 79 dash back together. Before I install the speedo/tach unit I want to be sure I don't have any vacuum issues with the headlight switch in the dash. My headlights turn on but they don't come up. With the car running...when I turn the headlights on I get a continuous vacuum hiss from the switch and no movement from the headlight doors. If this is ok I will button up the dash and move to under the hood to look for trouble. The override switch does not do anything in either position.
Mike
Old Mar 16, 2010 | 06:38 PM
TimAT's Avatar
TimAT
Running and you pull the switch the lights should come up.
I think Willcox has a vacuum diagram on his site. I wouldn't put the dash back together until I knew all works OK. But that's me. I don't think taking the dash apart is all that much fun.
Old Mar 16, 2010 | 08:31 PM
...Roger...'s Avatar
...Roger...
I was going to say because of the hiss that you have the 2 hoses switched at the HL switch but then you said the bypass doesn't work. As Tim said check out the Willcox diagram and make sure you have all the hoses right.
Old Mar 16, 2010 | 09:50 PM
ragtop00's Avatar
ragtop00
Thanks Guys,
I agree with checking the diagrams before buttoning it up. Am I going nuts or do the AIM and the Willcox diagrams contradict each other? The Willcox dia says "source vacuum to rear" and shows visually the source line to the port on the switch closest to the rear of the car when installed. The AIM on sheet 7 in 12C shows the opposite. I set mine up per the AIM diagram and going to copy Willcox for input.
Old Mar 16, 2010 | 10:32 PM
Peterbuilt's Avatar
Peterbuilt
Default Vacuum Connections!
Willcox is correct, the AIM in not.
Here's another diagram.
Old Mar 17, 2010 | 11:55 AM
ragtop00's Avatar
ragtop00
I'll let you all know what Willcox says. It's not the first time the AIM has been wrong.
To 79 Headlight switch vacuum question
