Hey fellas, you all have saved me once and I'm hoping you can save me again. First of all, let me just start off by saying the only reason I didn't notice my car was over-heating right away and pull over (radiator hose cracked), was because I unplugged my gauges that same day while fixing an a/c problem. I cannot believe my luck!!! Anyhow, the engine was recently overhauled. I was on my way to change the gasket and I noticed that these (retainers) were not pushed in all the way like the rest. Is that how they're supposed to be? I didn't want to keep going further until I asked the experts. Thanks in advance!
Ok, good... The reason why I thought it was the head gasket was because there was a little white smoke coming out of the exhaust when I started it back up and when I took the valve cover off, I saw water inside. Do you guys think I'm right? There aren't valve seals on this motor, right? That was my other guess as to what could have been going on but then I didn't see valve seals. Thanks again guys!
Oh, forgot to say, not sure how bad it overheated or even for how long... I felt it lose power (detonate) a bunch and then pulled over and started smelling smoke and seeing some from under the hood. =( I cannot believe the day I unplug my temp. gauge, a radiator hose cracks.... just overhauled!!!
Hmm, ok, it seems like you need a bit of engine parts definition training. Yes there are Valve Guide Seals in this engine, you can't see them because they are on the valve guides inside the springs under the retainers on top of the heads. White exhause is an indictor of coolant intrucion into the combustion chambers. you verified this by stating there was water under the valve covers. At least 1 blown head gasket is likely. If your lucky and it didn't cook bad all you may need is new gaskets. Could be worse, much worse. But thats for later. DO you have any friends that know motors to guide you thru this or is that what we are here for? Be happy to help wherever we can
YUK! I saw an engine that looked like that one some years ago- the owner used Quaker State oil and was changing it every 3k. He said. But it was a Ford too.
Unfortunately, I dont have any friends who know anything about cars. I've done/changed every single thing on a car but never had to "dig in" to the actual motor. Anyways, thanks for the clarification. So then I should just change that head gasket. Thanks! I didn't see any smoke on the other side of the car or water under valve cover so I hope I'm safe there. Should I go ahead and change the valve seals as well? I shall send you a beer to your home!
From: Graceland in a Not Correctly Restored Stingray
Sorry about your luck.
Cause being one thing and effect being another, just addressing the culprit could leave you in for more grief down the road. So, IMCO it's better to check deeper into things and find they are OK than to not check only to find out later there was more to it. Here are a couple of additional problems of which you should be wary...
If it got well and truly hot, if you experience a major increase in oil consumption rate you're rings are very likely toast, whatever the initial problem. Of course, it would be better to just do a leak down to check this before running it again.
Another thing you don't want to have happened is that enough coolant got into the crankcase to have diluted your oil to the point you lost the film and wiped the bearings. If there's much water in the oil, I'd pop the pan and take a look see...
First off. You posted that a hose cracked and then you pulled the intake to change a gasket. Care to explain what is going on there? Water leaking?
The intake gasket can also leak water into the intake ports and the oil.
Check the oil and see if there is any water in it.
The best thing may be to re-install the intake and connect and fill the system. Pull the plugs and pressure test the system. If it is leaking and you don't see where check the oil for water and turn it over and see if water comes out the plug holes. If either, then you have bigger problems so change the oil or WD-40 and then oil the crap out of the wet cylinders and get ready to pull the motor for a rebuild. If it doesn't leak then you're good.
If you don't know anything at all about engines then it's not a real good idea to start pulling heads off. You need to read some books and preferrably have someone help or watch someone the first time.
You do not want to put it together and then leave it overnight with a cracked head filling a cylinder. Then, when you next crank it the cylinder will hydro-lock and probably destroy the piston and possibly bend the connecting rod or even crack the block. That' why I said to pressure test with the plugs out. At worst, it will blow the water out of the plug hole.
Peter
