77 a/c heat
I wrote this up awhile back for this problem.
The problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine may be damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease to fix. Disassemble, clean & grease.
3) If you have a heater, the small vac. tube to heater hose valve underhood may be damaged from heat & need replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
You may be able to hear a leaking switch. A test can be done by removing a console side on your year model & pressing the switch together (engine running).
Switch fix may solve Temp. change- check rad. level, vac. tube line to heater valve in heater hose. Further check that the temp. lever is moving the "door".
