A/C fill problem
Old Mar 20, 2010 | 11:45 AM
Adam Wartell's Avatar
Adam Wartell
Default A/C fill problem
A year or two ago, I had some A/C work done at a local shop that included replacing the A/C lines.
Last summer, it wasn't cooling, so I went to add some coolant from a can.
I could not get the hose connected to the fill port because it is right up against the support bracket and bolt for the compressor.
Did the shop put the wrong hose on? Or is something else screwy here?
Old Mar 20, 2010 | 11:56 AM
jdmick's Avatar
jdmick
Have you considered a longer belt? It looks like that might get the bolt out of the way. Would be a lot cheaper than replacing that hose with the correct one.
Old Mar 20, 2010 | 12:12 PM
mds3013's Avatar
mds3013
Is there poss. a charge port on the accumulator tank under the pass. fender? mds...
Old Mar 20, 2010 | 12:20 PM
tommyleea's Avatar
tommyleea
Not necessarily wrong, but they do have angled fittings that would allow access. I have the same problem you do. I have to remove the mount bolt to charge. Unfortunately, you can't change the fitting now, without removing the hose from the back of the compressor. I don't have a fitting on my accumulator, and not sure if I could access it anyway. That baby is hidden away pretty good.
Old Mar 20, 2010 | 12:22 PM
Adam Wartell
I thought it has to be running to charge it. With the bolt out, you can't run it. I'm kinda liking the longer belt idea.
Old Mar 20, 2010 | 12:31 PM
Ganey's Avatar
Ganey
Worth checking, however if it's factory & like 77 a R134 adapter may go on, but would need to be angle for the R134 hose connector.
Old Mar 20, 2010 | 12:39 PM
Ganey's Avatar
Ganey
The belt needs to be very tight for normal operation. You could see if it could be tightened more or set loose to charge. To pull the bolt to charge you can put a spacer between the compressor & bracket visible in pic.
Old Mar 20, 2010 | 03:40 PM
noonie's Avatar
noonie
All you need is this type of fitting.
You need to evacuate the system to change it.
Since the shop should have really known better either order the correct fitting/and or take the car back to them and possibly work out an arrangement of some sort.
https://www.ackits.com/pc/35-50003/c...2890+Degree%29
Old Mar 20, 2010 | 09:47 PM
Adam Wartell
That looks perfect! Thanks for the link!
Old Mar 20, 2010 | 10:00 PM
Adam Wartell
I just ordered the part. I hope the clearance is enough between the fitting that is there now and that adjustment bolt. If not, I think I'll still have to look into the longer belt.
Old Mar 21, 2010 | 09:32 AM
tommyleea's Avatar
tommyleea
You are correct, and I know it sounds strange, but once I connect my charge hose, I can reinstall the bolt, and then crank it up. Remove bolt again, and remove hose. Yes it is a pain, but if everything is working you don't have to service very often.
To A/C fill problem
