best short block?
Old Mar 21, 2010 | 09:03 PM
kubesh's Avatar
kubesh
Default best short block?
hey everybody, I need to know who makes the best short block for a stoker, money is not an issue, I am thinking of making a 383 or should I go with more cubic inches while I am starting from scratch anyway. thanks.
Old Mar 21, 2010 | 09:31 PM
jackson's Avatar
jackson
Money no issue? I make the best stroker short block. Only Keebler labor and unobtainium material & tooling.
*everything on internet's suspect; including the very words I just wrote.
Old Mar 21, 2010 | 10:10 PM
vt72's Avatar
vt72
If money is no object then go big block JMHO
Old Mar 21, 2010 | 10:11 PM
BLOCKMAN's Avatar
BLOCKMAN
Go big if money is not an issue A Dart SHP block and build a 400 CID with a Callies rotator ETC. What are you using for heads??
Old Mar 21, 2010 | 10:22 PM
tigers123's Avatar
tigers123
If money is no issue get one from gm. It has a forged steel crank and if you don't like the cast pistons change to forged . Slap some afr 195 heads on it your choice of roller cam and away you go.
Old Mar 21, 2010 | 10:39 PM
MakoShark72's Avatar
MakoShark72
from your local GM dealer..a ZZ383 is $5100 with a 24 month/50,000 mile warranty.
http://www.gmperformanceparts.com/En...8772&engCat=sb
Old Mar 21, 2010 | 10:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
But fot the money this engine is a beast.
http://www.ultrastreet.net/engines/434_ultrastreet.asp
I would upgrade to the "nirtous package" and include the carb and ignition dialed in on the dyno.
Old Mar 22, 2010 | 05:44 AM
Tumarr's Avatar
Tumarr
LSX based motor. The cylinder heads available are far beyond the old antiquated small block chevys.
Old Mar 22, 2010 | 07:39 AM
kubesh's Avatar
kubesh
I was thinking about a Motown block from world products, how does the stack up against the Dart block?
Old Mar 22, 2010 | 09:18 AM
BLOCKMAN's Avatar
BLOCKMAN
We tried some World blocks years ago and was not pleased with their product and if we found some problems they would never take their block back, The last one we got was filled with epoxy up to the top of the freeze plugs and the customer did not want and neither did I and they would not take it back!!
We have seen cam tunnel issues, lifter bore placement issues ETC.
We had one in the shop a few months ago to repair the cam tunnel because of a spun bearing.
Dart blocks seem to be a better piece.
Old Mar 22, 2010 | 09:48 AM
kubesh's Avatar
kubesh
thanks for the info blockman
To best short block?
