looking for the correct water pump pulley
Old Mar 22, 2010 | 06:20 PM
another-user's Avatar
another-user
Default looking for the correct water pump pulley
my belts have never correctly lined up, and im getting sick of buying new alternator belts every 2 years.
this is for a 69 350/300hp, manual, no ac. i think all i need is a 2 groove pulley, one for the crank and one for the alternator.
i dont have the number for the pulley on hand, but i think it said it was a BB part when i looked it up a few years ago.
Old Mar 22, 2010 | 06:39 PM
DZRick's Avatar
DZRick
I've got some spare pulleys and my brother has a '69 350/350 non air I can match these to if you want.
Old Mar 22, 2010 | 06:43 PM
another-user
hmmm... i was planning on just swapping out the top pulley, as that lower ones going to be a real pita to get off.
let me know what your asking for the set.
Old Mar 23, 2010 | 11:37 AM
jackson's Avatar
jackson
au:
perhaps? ... maybe? ... your water pump is later 'vette specific' short pump that's just a bit longer than early short pump. Maybe?
*everything on internet's suspect; including the very words I just wrote.
Old Mar 23, 2010 | 01:40 PM
DZRick's Avatar
DZRick
Someone just posted the other day about buying the correct pulleys from a corvette salvage yard for $20 each.
I'll try to find the thread and link you to it.
Old Mar 23, 2010 | 01:55 PM
DZRick's Avatar
DZRick
Post # 15 in the following thread has the salvage yard name and number.
You'll probably be better off just calling them.
http://forums.corvetteforum.com/c3-t...mp-pulley.html
Old Mar 23, 2010 | 02:36 PM
another-user
cool, i just sent them an email. hopefully they can find something for me.
Old Mar 23, 2010 | 05:25 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Didn't see a PS pump in your pic. My 72 has ps and the alt.
For comparison, here's off-car images of my 2-groove WP and crank pulley's:
FWIW: my SB wp pulley looks different than yours. Allegedly, mine was never changed and they line up correctly on a NOM SB.
Hope you get a line on fixing your problem soon and get back where you want to go, literally.
Old Mar 23, 2010 | 06:04 PM
PeteZO6's Avatar
PeteZO6
Originally Posted by jackson
au:
I would give serious consideration to this idea. It looks like you have the correct pulley; the w/p pulley has a groove for the alternator, w/p and crank belt, one for just the w/p and crank, and finally one to drive the air pump. I ran into a similar problem when I installed a "short" GM aluminum w/p on my '69 that originally had the same 350/300 engine. If it is indeed the correct early Corvette short pump, then some bubba has changed the pulleys and you're on the right track to find correct ones.
(I fixed my problem by machining a spacer to move the crank pulley forward to match up with the w/p pulley.)
Old Mar 23, 2010 | 06:32 PM
another-user
ill pull the numbers off my pump and and pulley tomorrow.
i wish i could find my old water pump, i know its in the garage or basement.... somewhere.
i also know some one had their hands on this car before i or my dad had it (he bought it back in 74 or so) as ive found more then a few things that arent right. like the guts of my diff not being something that was offered by GM.
Old Mar 23, 2010 | 07:18 PM
another-user
ok, i lied. i went out and pulled it off just a moment ago.
Number on the WP Pulley - 391114 JH
Number on Current WP - 2244? 2241? hard to say. its a napa reman.
Number on Previous WP - GM23 8782808 F78
Old Mar 24, 2010 | 03:27 PM
another-user
ive been searching for a while now ont hese numbers and havnt come up with anything. anyone know what they are?
Old Mar 24, 2010 | 06:29 PM
PeteZO6's Avatar
PeteZO6
I may have misspoke in my post #9 above. The third pulley, for the smog pump, on the w/p is not of one piece with the two other pulleys. I realized that when I went to look at my car and the original engine sitting under the bench. Mine is a early November 1969 built car, so perhaps the pulleys were different from when your car was built, i.e., separate instead of all three integral.
The w/p on the original engine is marked GM23 3839176. It is NOT an original pump, it has a plugged opening on the top for a by-pass hose used in some applications - like yours in the photo. I measured the pump, it is 5 5/8" from the gasket surface to the flange on the shaft.
From the photo above, it looks like you may have the long short Corvette pump, used in the later C3s.
I know somebody in the past posted the difference in w/p lengths, and gave the year the change was made. I didn't find it using search. Perhaps somebody will chime in with the dimensions.
I hope this helps,
Pete
Old Mar 24, 2010 | 07:27 PM
another-user
i still think ive got a wrong pulley some place, either the wp or the crank. only reason i say this is because on the crank, the gap between the grooves is rather narrow, where as the gap between the grooves on the wp are measurably and visably wider. this can almost be seen in the 2nd picture.
so at this point it looks like ive got too long of wp, and either too wide of pulley, or too narrow of pulley.
The non severe duty pump for a Corvette up to 70 has the 5/8" shaft end and is Block to hub----5.625". This is 0.17" shorter than the commonly referred to Corvette pump of Block to hub----5.795"
Old Mar 24, 2010 | 09:12 PM
TimAT's Avatar
TimAT
I don't know if GM did the early SB Vettes the same as the BB's? I know they had some Z-28 Camaros with a single belt that was just around the crank and water pump, the one in front of that was to the crank/WP/Alternator.
Old Sep 22, 2012 | 03:21 PM
OldsJoe's Avatar
OldsJoe
1st Gear
I realize this is an old thread, but you have the wrong WP pulley. That is the WP pulley for a '66 to '68 Olds Cutlass & 442 with 330, 350, 400 or 455 with A/C & P/S. The matching pair (for the Olds) is as follows: The crank pulley is stamped 389645 JB, 3 groove and is 7 1/8" in dia & 2 3/16" deep. The water pump pulley is stamped 391114 JH, 3 groove and is 6 5/16" in dia. & 2 ½" deep. Hope this helps. BTW - You'll make some Olds person happy if you put it on Fleabay.
To looking for the correct water pump pulley
