Borgeson conversion install question.
Old Mar 23, 2010 | 01:34 PM
crf311's Avatar
crf311
Default Borgeson conversion install question.
I'm installing the Borgeson power steering conversion into a non power steering vette. My question is " Do I remove the steering damper set up and all the brackets which went along with it? Thanks
Old Mar 23, 2010 | 02:16 PM
Solid LT1's Avatar
Solid LT1
I never have seen a steering dampner on a C3 Vette only C2 models. I would remove it for the sake of simplicity, are you shure it isn't an old power steering cylinder?
Old Mar 23, 2010 | 02:29 PM
682XLR8's Avatar
682XLR8
Before I added power steering to my 68, it had a dampner. It will not be needed with the new steering box
Old Mar 23, 2010 | 03:05 PM
crf311's Avatar
crf311
Thanks, I called Borgeson, They said to remove it. I kind of th ought it would need to be removed because the pitman arm would not fit with the steering damper there. Thanks.
Old Mar 23, 2010 | 04:59 PM
blueray72's Avatar
blueray72
Randy, what is the part number of the unit you got? It was a kit right?
Old Mar 23, 2010 | 05:32 PM
682XLR8's Avatar
682XLR8
Yes, it's a kit. Sort of. The kit itself doesn't have a part number, but the components do. I'll get the numbers for you tonight
Sent you a PM on another matter. BIG NEWS
To Borgeson conversion install question.
