FUEL PUMP
Old Mar 12, 2002 | 11:19 AM
Ken74Conv's Avatar
Ken74Conv
Default FUEL PUMP
My '74 has a fuel pump with a return line. Is this common with all C-3's?
What is the purpose?
Has anybody plugged the return line and run a standard pump with (1) inlet and (1) outlet?
Would this be advisable?
Thanks,
Old Mar 12, 2002 | 12:24 PM
Stewart's74's Avatar
Stewart's74
Default Re: FUEL PUMP (Ken74Conv)
Ken, I know several forum members who have changed pumps and simply capped off the return line. No problem.
Stew
Old Mar 12, 2002 | 08:49 PM
rainman69's Avatar
rainman69
You can buy replacement pumps for $15. I bought a '73 pump to eliminate that damn $60 fuel filter. I say keep the return line, it keeps your fuel cooler and helps prevent vapor lock.
Old Mar 12, 2002 | 09:09 PM
killain's Avatar
killain
Oldtimer
I wouldn't get rid of the return line.
Old Mar 12, 2002 | 09:20 PM
aqua80's Avatar
aqua80
Ken, the way I understand it is the return line allows eccess fuel that the engine doesn't require to be returned to the tank. This serves mutiple purposes, 1: It allows the fuel pump to continually flow fuel thus reducing internal wear.
2: It prevents the fuel from becomeing warm as it sits in the supply line helping reduce vapor lock.
I would keep the return line....
Old Mar 13, 2002 | 09:06 AM
Ken74Conv's Avatar
Ken74Conv
Default Re: FUEL PUMP (aqua80)
OK! I'm convinced. I'll keep the return line.
Thanks for your help, guys!!
In case anyone wonders why this came up.
I pulled my engine in Jan. and am now rebuilding the front end.
Shortly I'll be ordering a ZZ4 as a replacement.
That's why the question came up.
[Modified by Ken74Conv, 8:10 AM 3/13/2002]
To FUEL PUMP
