Top A-arm bolts.......
Mar 23, 2010 | 02:49 PM
I think I already know the answer to this one, but...
Any way to get to them (and PROPERLY torque w/ loctite
) short of removing the radiator shroud, or maybe the radiator as well??
Yea, yea...I installed poly's and the bolts are starting to come loose (didnt know about the loctite w/poly'sat the time).
Thanks,
Rob
Mar 23, 2010 | 03:05 PM
If there is, I couldn't figure it out. I also could not remove the shroud without also removing the radiator itself.
I started with a front suspension rebuild in May of 2008, I now have a new engine that is e-fan wiring and a radiator hose away from running.
If I had it to do over again, I'd probably take a saw to the shroud and cut it out in pieces, and then go with e-fans for a while rather than de-commission the car for as long as I have, but the motor needed help anyway, so I reordered things a bit.
Here is my saga , I forgot that one guy mentioned that he drilled a 1" hole in the shroud to access the bolt. That's probably better than going scorched earth on the thing with a sawzall.
Mar 23, 2010 | 03:17 PM
Quote:
Originally Posted by
MakoShark72
Thanks,
Rob
Are you trying to remove the studs?
I used a slide hammer with a finger like hook --[||||]----)
From the wheel well, I slide hammered 4 of them out.
Mar 23, 2010 | 03:24 PM
jimvette999
The bolts that go into the ends of the cross shaft...
Mar 23, 2010 | 03:43 PM
You just want to redo the shaft bolts? Why don't you just pull the a-arms out again? It takes me 30 minutes to pull down a front corner of a C3.
Mar 23, 2010 | 03:48 PM
MakoShark72
Thank you..... now it makes sense.
MakoShark72
My bottoms (at least 1) came loose with loctite
Mar 23, 2010 | 04:02 PM
wcsinx
Thats a great idea....though it would probably take me longer than 30 minutes!!
But...I might use pulling the radiator as an excuse to install a Hot Cam, AFR 195's and an intake!!!!
Boys will be boys...."Honey, I HAVE to remove the radiator, may as well...."
Mar 23, 2010 | 04:31 PM
With poly
As you wriggle & curse ... getting to those end-bolts ... make dang sure you get inside the xshafts' threads & flush out well with brake/carb cleaner ... same goes for bolts threads ... all dry ... only then will threadlocker work.
*everything on internet's suspect; including the very words I just wrote.
Mar 23, 2010 | 04:44 PM
MakoShark72
30 minutes. Heck, nothing on my car takes 30 minutes. Takes me at least a half hour to prime and start it
