what intake?
Old Mar 24, 2010 | 11:44 AM
upnorth's Avatar
upnorth
Default what intake?
i have a 76 vette 350 .its has 65cc dart angle plug heads 202 the engine is bored 30 over and decked 40 it had a 350 350 kit installed back in the 90s it all balanced . auto with a 3500 stall converter and 373 gear. it has a torker2 on it but it doesnt seem to have a lot on low end .what intake would you suggest i have a holley 600 on it now .
Old Mar 24, 2010 | 12:35 PM
jordan89's Avatar
jordan89
What cam are you running?
Old Mar 24, 2010 | 01:01 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The Edelbrock Performer RPM is a nice intake that should restore your low and mid-range torque.
Old Mar 24, 2010 | 02:34 PM
upnorth's Avatar
upnorth
its been years but i think its a 480 i also have crane roller rockers.
Old Mar 24, 2010 | 03:47 PM
djcwardog's Avatar
djcwardog
Default Edelbrock Performer RPM Air Gap
I think this is the proper name for it... Anyway, Hot Rod magazine seems to love these for any motor when they do comparo dyno tests... So, I would consider it strongly, especially as your Torker experience tracks perfectly with what that magazine reports as well...of course, Edelbrock says these won't fit under our stock hoods... Not an issue for you if you are going with a different hood, otherwise... I went with a 1968 aluminum 427/390 intake on mine as the best choice for me and my 454 when keeping the stock hood.
Old Mar 24, 2010 | 04:02 PM
wcsinx's Avatar
wcsinx
Don't quote me on this, but I've heard guys here claim that it just barely clears a '76 hood if you use a drop base air cleaner.
check out post 9 for example
http://forums.corvetteforum.com/c3-t...-or-stock.html
Old Mar 24, 2010 | 04:20 PM
Ganey's Avatar
Ganey
The RPM fits.
The med. rise hood 76-79 hood allows RPMs, Victor Jr. & others w/ Holley, about 1"+ drop base & about 3" filter.
Old Mar 24, 2010 | 06:42 PM
upnorth's Avatar
upnorth
what about the wieand stealth .
Old Mar 24, 2010 | 08:06 PM
Ganey's Avatar
Ganey
Weiand Stealth fits as above.
Old Mar 24, 2010 | 09:22 PM
upnorth's Avatar
upnorth
which is better the weiand or the edlebrock?
Old Mar 25, 2010 | 01:40 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
For your cam I feel the edlebrock RPM will do very well. As for the Cam the 480 only tells us lift not duration. But if it is an old cam with 480 lift then it sounds like an old Cam Dynamics or General Kenitics cam which was a 480 lift 288 duration as advertised. Good ole cam to be honest.
Old Mar 25, 2010 | 07:05 AM
Phil Zell's Avatar
Phil Zell
I am running the Weiand Air Strike and have tons of low end torque. Any good dual plane intake will help on low end
Old Mar 25, 2010 | 07:58 AM
MrGoFaster's Avatar
MrGoFaster
Hot Rod magazine seems to love these (air gap) for any motor when they do comparo dyno tests... So, I would consider it strongly, especially as your Torker experience tracks perfectly with what that magazine reports as well...
I would second this. I've done a lot of reading up on intakes & the Air Gap seems to be the best bang for your buck you can get, although just slightly better than the Performer. You can find either on ebaY for a very reasonable price.
Old Mar 25, 2010 | 06:20 PM
upnorth's Avatar
upnorth
been looking at some of the crate engines and from what ive seen it seems like under 400 hp there using the regular edlebrock rpm and over 400 hp there using the air one .i have no idea what mine is or is capable of in hp .but i do have the 3000 stall converter and 373 gear they say to use .
To what intake?
