rear end
Old Mar 30, 2010 | 11:53 AM
  #41
63mako's Avatar
63mako
St. Jude Donor '08-'09
See GTR1999 quote in post #31. It is great to have forum members that have more knowledge about Corvette differentials than Gary. To me running a differential with the yokes ground down to the point you have 1/4" of endplay in the axle is similar to continue to run an engine with a wiped cam lobe. They both still work, They both have metal debris floating around in the oil and because of this they both are damaging other components that will lead to more expense when you do rebuild it. In my opinion metal shavings and chunks of C clip are not great lubricants but what do I know. I would think it would cause excessive wear on the ring and pinion gears, bearings and races, spyder gears, carrier pin and if you run a chunk of the c clip through thru the spyders a busted posi case, or if it runs through the ring and pinion busted teeth on those but, like I said I am just an old school hotrodder and don't have my engineering degree so what would I know. You would think a member with an engineering degree would realize this and know better than to give advice to continue driving it as is. I must be way stupider than I thought or am missing something here.
Old Mar 30, 2010 | 12:16 PM
  #42
pauldana's Avatar
pauldana
Originally Posted by wcsinx
Wrong
Quote:
Originally Posted by pauldana
happened to me also...
No ... no it didn't.
ummm ok..... wait!! yes it did!!! lol.... my yoke was chewed up, and yes it definitely did make it feel like a boat.... and again... fixed it, problem went away.... so...
Old Mar 30, 2010 | 12:34 PM
  #43
bashcraft's Avatar
bashcraft
It felt like a boat because the camber was so far out from the yokes being so badly worn, not because the yokes were pulling out of the rearend.
Old Mar 30, 2010 | 12:43 PM
  #44
wcsinx's Avatar
wcsinx
OOOH ok, so the yoke was chewed up throwing off your camber, but the reason the rear went squirrely is because the c-clips fell off? Is that really what you're trying to say? So when you "fixed it" did you just put new c-clips on, or did you replace the stub axles and realign the rear? :
ding ding ding!
Old Mar 30, 2010 | 01:26 PM
  #45
Mike Ward's Avatar
Mike Ward
That's it but we're past that now.
Old Mar 30, 2010 | 01:36 PM
  #46
pauldana's Avatar
pauldana
ding ding ding!
They WERE able to get an alignment on it with the chewed up yoke....but the wheel would not stay aligned in curves because of all the play....
so... several months later when I could afford it (15 years ago) I pulled the rear and fixed it, put it back together, no more boat....
Old Mar 30, 2010 | 01:44 PM
  #47
wcsinx's Avatar
wcsinx
Sorry, not true
Like I said, unless the wheel is off the ground or slamming into something laterally, that stub axle will remain loaded inward. Period.
Did you verify they set the camber correctly? Did you make sure your strut rods were secure?
And what else did you fix/replace when you had the pumpkin out? Did you reset the camber?
Old Mar 30, 2010 | 01:52 PM
  #48
Mike Ward's Avatar
Mike Ward
So please explain how there's many documented examples of Corvettes running around with NO c-clips in place and they have NO camber changes?
How come a 3D analysis of the suspension geometry confirms that the yokes are always loaded inwards?
Better yet, why am I getting sucked into this futile debate again?
Old Mar 30, 2010 | 02:18 PM
  #49
pauldana's Avatar
pauldana
ok.... im laughing little here.... don't want to ruffle anyones feathers...
when the vet sat, yes it was aligned properly, just as you say... agree...but when in a high g force to the right or left, the wheel would pull out as the car leaned, and thus loose its alignment, causing a boat effect...it was the same as lifting that wheel off the ground a little, just as you explain...
and the yoke and c-clip were the only things that needed to be replaced....
The yokes are loaded inwards, unless in a strong lateral force, then the opposite outer side wheel is no longer loaded downward but rather dragged outward...
Old Mar 30, 2010 | 02:38 PM
  #50
Mike Ward's Avatar
Mike Ward
Please show your calculations to support this conclusion.
Old Mar 30, 2010 | 02:42 PM
  #51
pauldana's Avatar
pauldana
I have no calculations, :-)..... just my experience of what happened to me..... thats all..... nothing more, nothing less...
Old Mar 30, 2010 | 03:23 PM
  #52
Mike Ward's Avatar
Mike Ward
So, refer to all the posts where those of us have actually taken the time to do the calculations and found out that GM got it right. There's a reason why the lower shock mount is mounted at a specific distance inboard of the wheel centreline. Wasn't just random placement or just for tire clearance.
As the lateral force increases, so does the downward force on the tire as the car leans. The net effect increases the inward pressure on the yoke, not decreases.
Old Mar 30, 2010 | 03:37 PM
  #53
pauldana's Avatar
pauldana
on one side, yes, but decreases on the opposing, just like jacking the car up on one side...
Old Mar 30, 2010 | 04:05 PM
  #54
Mike Ward's Avatar
Mike Ward
No, not at all comparable. I give up, over to the other guys with more patience.
Old Mar 30, 2010 | 04:14 PM
  #55
pauldana's Avatar
pauldana
Mike, I understand, and you seem to be very knowledgeable, im sorry.... dont mean to try you patience, this is just my experience of what happened to me...but, it was 15 years ago.... so....
I am going home tonight, getting under the car and taking a good look at the geometry of the whole thing...I could be wrong, but I don't think so at this time....
you state, that when the car is jacked up the wheel will pull from its axal? correct?.... so, in a lateral lean, say to the left turn, the right tire will be hard in, but the left tire will be loosing weight, thus pulling outwards... why would this not be correct?....
i am truly open to input... thx, p
on a ps... just went out back. i have a complete C4 IRS sitting on the ground... loosened a u-joint u bolt to try and simulate my idea of lean, got several students to put a simulated lateral lean on the IRS and sure enough the outer wheel pulled outward, just as i have stated....
Old Mar 30, 2010 | 04:28 PM
  #56
63mako's Avatar
63mako
Originally Posted by tmscarguy
ok, i appreciate all the help with the rear alignment question i posted. i had the car aligned, the bushings and bearings seem ok. but, the axle shaft that goes into the rear end has some slack in it. it goes in and out 1/4 inch or so with the car jacked up. it does this when you hold the tire at 6 & 12 and push/pull on it. nothing else moves except that shaft goes in and out. this car only has 27k on it. surely the rear end wouldn't be wore out. would it?
thanks, bob
This got way off track. This is the original post. In my opinion with 27,000 miles on the car and the side yoke having 1/4 in and out movement similar on both sides. I would pull it, inspect everything, Install a minimum of a basic bearing, race, seal rebuild kit with 2 new side yokes and c clips. I hope other internal parts have not been damaged beyond repair if they are not, great, if they are they too will need replaced. As I stated before with .250 end play if your side yoke dust flange is not digging into the case it don't have far to go before doing so. Why wait and trash the housing too?
Edit: Just looked up your profile. Your car is a 1978. That explains a lot. I believe the 1978, 1979 cars had defective, improperly hardened side yokes from the factory. They were very soft and wore down much quicker than the previous C3-C2 side yokes. Replace them.
Old Mar 30, 2010 | 05:11 PM
  #57
Mike Ward's Avatar
Mike Ward
Of course it did, you probably could have gotten that result with a 95 year old granny. The pivot point is at the junction of the strut rod and the lower shock mount. Measure the ratio of tire wheel ABOVE the pivot point compared to below. Let's say it's 3 to 1. That's the leverage you created by pulling on the top of the tire and not pushing on the bottom.
I guess you're not a physics, engineering or geometry major are you?
To rear end
Old Mar 30, 2010 | 05:24 PM
  #58
pauldana's Avatar
pauldana
I am a EE major, masters... specialty in RF engineering.
have a General contractors license also, along with a Pilots license...
I currently teach Computer graphics at a local high school, and have been building and modifying cars since I was 14yo, started on my first CJ5.... I have also taught several years of auto shop.....So, yes i have the capability to understand:-)
I will go home tonight, jack up the rear of my C3 and take a closer look....
but, anytime you put more force on one side the other will have an equal but opposing force... 1 pulling, one pushing....
ps.... my spelling sucks though!!! p:-)
Old Mar 30, 2010 | 05:29 PM
  #59
Gordonm's Avatar
Gordonm
If the C clips are not needed then why are they there in the first place. Just asking.
Old Mar 30, 2010 | 05:36 PM
  #60
wcsinx's Avatar
wcsinx
Yes, weight shifts from the inner to the outer wheels in a turn. But as Mike has told you, people have done the sums out to 1.3g, and it's not enough to overcome the 300 lbs inward preload on the stub axles.
I may be wrong, but I do not believe the C4 rear suspension uses the axles as its upper suspension links the way a C3 does.
