0.15 steel shim
Old 03-25-2010, 08:33 AM
wicho
Cruising
wicho's Avatar
Default 0.15 steel shim
i am installing vortec type heads with flat pistons on my 350 and 270h cam this will get me in the 9.35 to 1 range oh the heads are 64cc someone said to use ..15 steel gaskets do you recomend this to bring up the compression or should i go with traditional gasket and if so wich one do you recomend?
Old 03-25-2010, 01:33 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
I used the steel shim gasket with the same combo, same cam etc. Make sure you spray some aluminum paint on both sides of the shim gasket
Old 03-25-2010, 01:51 PM
jackson
jackson's Avatar
Not all steel shim gaskets are same. Some are coated & some are not.
Felpro p/n 1094 is 0.015" thick, has 3.2cc volume AND has a rubbery elastomeric coating; thus NO additional paint, sealer or other coating should be applied to it. Do suggest clean both decks & heads with brake cleaner & dry just before install.
me thinks you'll be above 10:1 scr
http://www.power-21.com/federalmogul...lculator4.aspx
*everything on internet's suspect; including the very words I just wrote.
Old 03-25-2010, 02:05 PM
MotorHead
MotorHead's Avatar
Then that would be a coated steel shim gasket, he asked about a steel shim gasket, only kidding around
Anyway I had about the same combo and with the right parts I made 296RWHP
To 0.15 steel shim
Quick Reply: 0.15 steel shim
