Valve Spring Shims. Need Help Quick!!
Old Mar 25, 2010 | 04:03 PM
jordan89's Avatar
jordan89
Default Valve Spring Shims. Need Help Quick!!
I am about to order some parts and need help deciding what valve spring shims I should go with. I am ordering from Jegs and don't know if I should go with the Jegs brand shims, or the Comp Cams shims. What do you guys think/prefer?
Comp Cam Shims:
http://www.jegs.com/i/Comp-Cams/249/4753/10002/-1
Jegs Shims:
http://www.jegs.com/i/JEGS/555/20590/10002/-1
Old Mar 25, 2010 | 04:43 PM
jordan89's Avatar
jordan89
Ttt
Old Mar 25, 2010 | 04:56 PM
MelWff's Avatar
MelWff
are you replacing the springs? If so go with the same brand.
Old Mar 25, 2010 | 05:00 PM
jordan89's Avatar
jordan89
I'm adding a cam and using the Summit Racing springs:
http://www.summitracing.com/parts/SUM-174000/
Old Mar 25, 2010 | 05:12 PM
MelWff's Avatar
MelWff
not clear if you already bought the spring kit from summit if not buy this kit from summit
http://www.summitracing.com/parts/CCA-4753/
Old Mar 25, 2010 | 05:18 PM
jordan89's Avatar
jordan89
That's the same kit I'm thinking about getting from Jegs. I think I'm going to go with the Comp Cams kit.
To Valve Spring Shims. Need Help Quick!!
