Summit racing pistons
Old Mar 25, 2010 | 09:43 PM
richiev88's Avatar
richiev88
Default Summit racing pistons
I have just bought a 69, the previous owner had recently rebuilt the engine. He has used Summitt racing hyper flat top pistons.
#sum-17350-60
I believe these will give me 9.8:1 with 64cc heads
How terrible or not are these pistons? The block is no origional 2 bolt and has been bored .60 over., so figued I would just run it, not worth replacing pistons on a 60 over 2 bolt.
He had replaced the crank with a new scat cast crank, std rods.
I do plan to replace the short block, when budget allows.
I have bought some AFR 195s and and a cam (282s, comp)to give it a wake up before I build a 383 short block.....but I dont want to risk damage to my new heads if these pistons are junk.!
Has anyone used these pistons, experences?
Richie
Old Mar 25, 2010 | 10:40 PM
BLOCKMAN's Avatar
BLOCKMAN
#sum-17350-60
Richie
I don't use Hyper pistons in the engines we build, But if you are conservative wit your tune up you should be fine.
With performance builds I don't find many 010 blocks that will pass a sonic test and be safe and have good ring seal at .060
From what I have seen all 010 blocks need to be sonic tested before any work is done/
Old Mar 25, 2010 | 10:51 PM
richiev88's Avatar
richiev88
I plan to use a new block for the 383. Is there a hp range for hyper pistons? With the AFR heads and cam I figure should not have much more than early 400's hp.
Old Mar 26, 2010 | 12:30 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
HP don't kill the hyper pistons. Detonation does. The cam with compression 9.8 to 1 should be fine. Advance the timing too much or run lean and you could have problems. Those heads are a modern chamber and should run @ 32 degrees initial and mechanical timing. Don't push timing to 36.Your short block has a cast crank, stock rods and hyper pistons. That solid flat tappet would pull rpm past the capacity of the bottom end. It is a 6000 RPM redline build, just so you know. A rev limiter would be money well spent.
Old Mar 26, 2010 | 12:42 AM
richiev88's Avatar
richiev88
I agree 6000RPM will be max. It has a MSD box, so should be able to put a 6k pill in it.
Forum advice tends to lean towards me needing a bigger cam to run with the AFR heads, on this short block. I was going to use a Isky Z30 or the old 30-30 comp cams grind, but thought I would lose to much vacum and put the power band to far above the current bottom end, appreciate your thoughts
Thanks Richie
To Summit racing pistons
