Motor mounts
Old Mar 26, 2010 | 10:05 PM
ssenay72's Avatar
ssenay72
Default Motor mounts
So i might try to tackle motor mounts while im dropping the oil pan tommorow. (if i can find some locally that is).
As far as jacking the engine up. I've read several methods, but since i will have the oil pan off would it make sense to use a 2x4 right on the edge of the block itself (where the pan mounts). Thinking i might avoid any pan damage this way. (although my stock pan is dented to all heck, not by me).
If not then ill go at the front of the pan, its being replaced anyway.
Old Mar 27, 2010 | 12:30 PM
ssenay72's Avatar
ssenay72
Well I found some motor mounts, problem is the headers are in the way. No way will I get that cross bolt out with them in. Might just wait until I get a new motor at this point.
