74 Vacuum advance
Old Mar 31, 2010 | 09:00 AM
RAStratton's Avatar
RAStratton
8th Gear
Default 74 Vacuum advance
I'm replacing the stock Carter/Holley carb with a new Edelbrock on the stock manifold. The new carb doesn't have all the same vacuum ports, and I also have a vacuum advance solenoid mounted on the right-front side of the intake manifold, which connects between the carb and the distributor vacuum advance. According to the service manual, the solenoid is supposed to shut-off vacuum to the carb when the ignition is off, which doesn't seem to make sense to me because you don't have vacuum when the engine is off anyhow. I'm thinking I can eliminate this solenoid and connect the vacuum advance from the distributor directly to the carb vacuum port. Does anyone have advice or agree/disagree?
Old Mar 31, 2010 | 10:13 AM
MelWff's Avatar
MelWff
since your car is not stock you dont need the solenoid. it's there for emissions purposes.
Old Mar 31, 2010 | 12:13 PM
TopGunn's Avatar
TopGunn
That solenoid is there to completely close the throttle plates when the ignition is turned off to prevent dieseling. If you've removed the smog stuff it most likely is not needed any longer.
Those are great solenoids to use in cars that have A/C to boost the idle speed when the compressor kicks in. You rewire it to the compressor so when you turn on the A/C it energizes the solenoid and boosts the idle a little to prevent the engine from stalling.
Old Mar 31, 2010 | 01:43 PM
Paul L's Avatar
Paul L
Do you have a photo of your setup? The stock carb is a Q-Jet.
Old Mar 31, 2010 | 04:27 PM
rip74's Avatar
rip74
You may consider using "manifold" vacuum, not "ported" vacuum. I have an Edelbrock Thunder series carb and performer EPS intake on an L-82. I'm running the vacuum advance from the manifold fitting with much better results than using ported vacuum. If you are interested, look under the Timing and Vacuum Advance section on: http://lbfun.com/Corvette/Tech/vettetech.html
Old Mar 31, 2010 | 04:41 PM
Paul L's Avatar
Paul L
I agree and I do use manifold vacuum. But unless he tells us what carb and manifold he has then guidance is not possible.
Old Mar 31, 2010 | 05:15 PM
Mike Ward's Avatar
Mike Ward
Wrong solenoid, wrong side of the car. The OP is talking about a TCS set up.
Paul 74 is probably world's leading expert on this stuff, I see he's on the scene.
Old Mar 31, 2010 | 05:38 PM
Paul L's Avatar
Paul L
Yes, he was talking about the A/C idle stop solenoid. The transmission controlled spark (TCS) solenoid (in my pic) is a different animal.
But whatever, we still do not know what carb we are speaking of. Manifold vacuum (yes I used last year) can differ from one unit to another.
Old Mar 31, 2010 | 06:02 PM
RAStratton's Avatar
RAStratton
8th Gear
Ok, now I'm really confused. I looked at Eckler's and Corvette Central site for a replacement solenoid and they call it a TCS solenoid (as you said) but note that it is for a manual transmission, and I have an automatic tranny!!
To answer your question I'm replacing the stock carb with a Edelbrock 1400, which is set up for EGR valve that I have, and also has a "ported vacuum" outlet and a "manifold vacuum" outlet. The manual says the solenoid allows the vacuum advance to be vented to the atmosphere when non-energized and vacuum applied to the vacuum advance when energized. Just wondering if this is really necessary and I should replace the solenoid (since I don't think it is working anyhow), or can I just connect the vacuum advance hose directly to the carb (either ported or manifold vacuum).
Sorry I forgot to mention I'm using the stock manifold with the Edelbrock adapter plate.
Old Mar 31, 2010 | 07:11 PM
Paul L's Avatar
Paul L
Go with manifold vacuum. I don't know what an Edelbrock 1400 is but here is the manifold vacuum on a #7044206 Q-Jet, just below the choke ***'y.
Old Mar 31, 2010 | 08:57 PM
TopGunn's Avatar
TopGunn
OK. Sorry for the mis-information.
To 74 Vacuum advance
