Looking for a decent hi torque mini starter...
Old Mar 31, 2010 | 10:58 AM
MakoShark72's Avatar
MakoShark72
Default Looking for a decent hi torque mini starter...
...for a 10:1 SBC.
There's dozens on ebay, from 49.95 up thru a couple hundred bucks...
Are the $150 ones really that much better??
Thanks.
Old Mar 31, 2010 | 11:40 AM
JLeatherman's Avatar
JLeatherman
When I went to a ministarter I purchased one for a 92-96 LT1 vette. They came from the factory with a ministarter, and it's a great piece. I think it was like 90 bucks and it was in stock at my local carquest. Word of caution, though. If your local parts place has to order it be careful because some places (like autozone) list several starters that "fit" the 92-96 vettes and they throw in standard SBC starters as replacements, not the correct one. Might wanna go armed with the part number for the correct GM one and see what it crosses over to now.
Old Mar 31, 2010 | 12:09 PM
gkull's Avatar
gkull
The late model Vette Nippon Denso is a great starter. I have the Summit racing brand gear reduction highest TQ rating
Old Mar 31, 2010 | 01:09 PM
68/70Vette's Avatar
68/70Vette
I've bought three ministarters from the General Motors Performance Part catalog. They appear to be of good quality and I've had no problem with them. (2 ministarters for a SB and a high torque ministarter for a 502 that I plan to build). Actually, I got their part numbers from the GMPP catalog and actually bought them from Summit.
I've had no problem with them Well actually one of the ministarters exploded. I had a problem with my 68 ignition switch. When you turned the key to "start," a spring in the switch should place the key in the "run" position when you release the key. With my problem switch, you had to manually rotate the key from "start" to "run" as soon as the engine started. I once started the engine of my ZZ4 and forgot to turn the key to "run." With the engine running and the starter still engaged on the flywheel ring gear, I blipped the engine to about 2500 rpm. This caused a gross over rpm condition for the starter. The rotor broke apart from centrifugal force and jammed into the stator. Instant destruct. Anyhow, I replaced the ignition and bought the second ministarter.
Old Mar 31, 2010 | 01:16 PM
markdtn's Avatar
markdtn
or C4 TPI or early 90s pickups/Suburbans.
Old Mar 31, 2010 | 02:05 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I have a Chrome CVR mini starter I never used on my 427ci it has never been energized, it is supposed to be the best one out there
If you want it let me know I want 200 bananas for it
It comes in the original box with shims and instructions. Basically brand new in the box
http://www.dougherbert.com/protorque...r-p-16779.html
"State of the art construction make them one of the strongest and most durable Nippondenso gear-reduction starters on the market. Unique aluminum housing eliminates hot start problems. 1/3 smaller, 80% more cranking power (1.9HP), 40% lighter and 50% less amperage draw than stock. 4:1 gear ratio. They offer one of the most versatile header and oil pan clearance adjustments on the market."
Old Mar 31, 2010 | 02:08 PM
Shark Racer's Avatar
Shark Racer
Motorhead - thanks a lot, jerk. I went blind after looking at that photo.
Old Mar 31, 2010 | 02:41 PM
MotorHead's Avatar
MotorHead
You won't be talking smack tomorrow, I get my Yellow 10 year CF designation
Old Mar 31, 2010 | 07:45 PM
C3 Stroker's Avatar
C3 Stroker
I've used the Powermaster XS Torque starter for over 10 years now, and it's still going strong. Kinda pricey, but has 200 lbs. of torque, is good for 18.0 C.R. engines, and weighs only 7 1/2 lbs.
Link.....http://www.summitracing.com/parts/PWM-9500/?rtype=10
Old Mar 31, 2010 | 08:43 PM
chvet73's Avatar
chvet73
Mine has been great too
Old Apr 1, 2010 | 12:32 AM
richiev88's Avatar
richiev88
Does the GM LS style stater fit pre 86 SBC ?
To Looking for a decent hi torque mini starter...
