ZDDP Plus Oil Additive
Old Apr 1, 2010 | 05:10 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default ZDDP Plus Oil Additive
The Eastwood company has it on sale for $5.99 for 4 oz. bottle.
http://www.eastwood.com/zddp-plus-oi...m_medium=email
Old Apr 1, 2010 | 05:56 PM
TedH's Avatar
TedH
I intend to check the price on CD2 High Performance Oil Boost this weekend. I need to change the oil in both the L48 and my Yamaha motorcycle (both are 30 years old this year).
Old Apr 1, 2010 | 09:38 PM
jordan89's Avatar
jordan89
I saw that in an email they sent me. I'm planning on ordering a couple since I'm going to be installing a cam in the Vette.
Old Apr 2, 2010 | 12:48 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Just placed my order for 6 bottles!! THANKS!
Old Apr 2, 2010 | 09:08 AM
csradley's Avatar
csradley
Just checked their website, shows for 9.00 and some change. I guess the sale is over...
Old Apr 2, 2010 | 09:45 AM
early shark's Avatar
early shark
I have a package of 5 bottles of ZDDPlus that I just ordered and received. I will sell for my cost of $44.25 + shipping. I am using Brad Penn's 10W-40 High Peformance Oil and the manufacuturer does not recomend adding any additives to their oil, hence the sale.
Old Apr 2, 2010 | 11:34 PM
glen242's Avatar
glen242
Oil manufacturers do not recommend adding addiutives to their oil.
Why not just use oil that has the proper amount of ZDDP, in the first place?
I use Valvoline VR1 10W30 in my flat tappet stroker. Valvoline (and most other manufacturers) web sites should have the specs. Use whatever oil suits you.
BTW, just bought another case of VR1. $4.50 a quart, but a far cry from the price of the boo-tique oils.
I am always amazed, that people who claim to care about their cars, keep searching Wally World for the cheapest oil they can find, and it usually does not suit their car.
Old Apr 2, 2010 | 11:49 PM
billla's Avatar
billla
St. Jude Donor '14
Old Apr 3, 2010 | 12:13 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Also GM says not to use additives in Corvettes period. I use Valvoline SynPower 10w30. Has everything your engine needs. I buy the 5 quart jug for around 20.00 @ WalMart
Old Apr 3, 2010 | 12:20 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Because manufacturers sometimes misrepresent the composition of their oil.
I have seen posted analysis of both Valvoline VR1 and Brad Penn oil that did not have the accepted minimum amounts of Zinc & Phosphorus. Maybe the analysis was wrong, but how do you know?
I have started running an additive for ZDDP just to be sure. I know oil companies dont recommend them, but it makes me feel better.
Since I am running a flat tappet cam with over .600" lift, I like knowing.
Old Apr 3, 2010 | 12:24 AM
billla's Avatar
billla
St. Jude Donor '14
That oil is API SM rated - so it can't have more than about 800 ppm ZDDP, which is not sufficient for a flat-tappet cam engine.
Their own MSDS lists Zinc at 840 ppm, and phosphorus at 770 ppm - far under the 1200 ppm minimum required.
http://www.valvoline.com/pdf/SynPower.pdf
Check the sticky at the top of the section...everything you need to know is there.
Old Apr 3, 2010 | 12:26 AM
billla's Avatar
billla
St. Jude Donor '14
You know by checking the sticky at the top of this section, and reading the VOAs. You should be running 1400 ppm or better ZDDP with that lift.
But extremely high levels of ZDDP can cause deposits which cause detonation, as well as having an adverse affect on lubricity of the oil. This is just some of the reasons they're not recommended.
Brad Penn clearly does NOT have sufficient ZDDP for flat-tappet cams regardless of their claims. The jury is still out on VR1, but I have a sample in for testing along with Royal Purple XPR.
Old Apr 3, 2010 | 12:51 AM
Syn Power is 1200
Old Apr 3, 2010 | 12:53 AM
SynPower is the correct oil according to Valvoline. They have been the number one oil for race cars for 150 plus years.
Old Apr 3, 2010 | 12:06 PM
jordan89's Avatar
jordan89
I just run Royal Purple on my car and forget the additive. I've been running it in my Camaro for about two years now and never had a problem.
Old Apr 3, 2010 | 01:30 PM
early shark
That's why I have the oil additive up for sale, I am using an oil with enough Zinc and Phosphorus, which in my case needs to be above the so called threshold amounts of 1200 ppm.
Old Apr 3, 2010 | 03:05 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
So, bottom line : why is it "not safe" to use ZDDP additives in our oils while cam manufacturers do recommend or even mandates to use them with the critical break-in period and sometimes will recommend to use the break-in additive (which to my knowledge is nothing but a ZDDP additive) in every oil change.
Lets face it, engine oil manufacturers will not recommend using ANY oil additive simply because they believe that if you want a high ZDDP oil you should simply buy a high ZDDP oil from their products range, I really don't think that it has anything to do with chemistry!
To ZDDP Plus Oil Additive
Old Apr 3, 2010 | 03:59 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Syn Power is 1200
It is not according to Valvoline's listed MSDS. Do you know something to contradict their analysis of their product?
SynPower is the correct oil according to Valvoline. They have been the number one oil for race cars for 1500 plus years.
Do not believe them.
Old Apr 3, 2010 | 04:08 PM
63mako's Avatar
63mako
Have any of you disassembled a 30 year old engine and noticed a thick, black, tarry "gunk" sitting on all the horizontal surfaces in the engine? A lot of this is ZDDP from the old oil formulations. Modern additives are engineered to keep this additive in suspension. Moly is another additive that is now formulated to stay suspended. Aftermarket ZDDP additives don't necessarily have this capability. Zinc is heavy, it sinks. Buy the oil that contains the correct levels for your application formulated into the oil. Don't dump "gunk" into your engine.
Old Apr 3, 2010 | 05:51 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Why not put a sample of Brad Penn oil in too ? My buddies shop has not had a single cam failure since he switched to BP oil in his new engines over 2 years ago
Now don't get all tied up in a knot here, I would like to know myself since I am running this oil in $15,000 engine
