Whats in your car?????
•Procharger D1SC 4" pulley, K&N filter
•383ci SBC
•9:1
•Forged Scat Crank
•Forged Scat 6" Rods
•Forged Aluminum SRP Pistons
•AFR 195cc Aluminum Angle Plug Heads w/8032 Upgrade
•Comp Hyd Roller Cam & Lifters .576 in .594 ex Lift 239in 245ex Duration @ .05
•Comp Chromeoly Pushrods
•Harland Sharp 1.65 Full Roller Rockers
•Edelbrock Victor Jr
•MSD Pro Billet HEI
•Mighty Demon 750 Annular
•Hamburger 7 qt oil pan baffled
•ProForm aluminum high flow water pump
Transmission:
•T56
•Pro 5.0 Shifter
•Spec Kevlar Clutch
•Centerforce Flywheel
Exhaust:
•Long Tube Equal Length Ceramic Headers
•Dual 3" Mandrel Bent Pipes
•Magnaflow high flow catalytic converters
•Dynomax bullet mufflers
Suspension:
•3.55 LSD
•630lb front coils (550s -3/4 coil)
•360lb rear spring (shortened 1/2") w/10" bolts
•Solid Precision U-Joints
•Bilsteins
•1 1/4 fast Corvette front sway bar
•3/4 Addco rear bar
•19x9 1/2 Enkei wheels
•275 30 Nitto NT555 tires
•19x8 up front with 235 35 Nittos
•Energy Suspension poly bushings
•Dana Ball Joints
Misc:
•Northern aluminum radiator with dual 12" electric fans
•Hawk Brake Pads
•Goodridge Stainless Steel Brake Lines
•Painless temp control
•Mobil 1 in the engine and Redline in the trans and diff
•The car has been lightened several hundred lbs
Believe you can disregard the 69-79 notation as long as you have the T10.
[/QUSo I spent half the day looking for hurst part number 3738621. this is the install kit for a comp plus shifter. Nobody has it anymore. I know its a T-10 and I know I have an 81. BUT: that part number is for 80-81 only WTF
•OEM Ram Air system (reconditioned) with paper element air filter
•Dr Rebuild Vacuum hose systems throughout (all 5 systems)
•.020" over 350ci L48 (OEM)
•.020" under cast crank (OEM)
•Powdered metal connecting rods (OEM)
•Speed Pro Hypereutectic Aluminum Pistons (H345NP)
•Hastings Moly Rings
•Cloyes True Roller Timing Chain
•Mellings High Volume Oil Pump
•Clevite/Michigan 77 bearings (main/rod/cam)
•Fel-Pro gaskets/seals
•DART 180cc Iron Eagle Straight Plug Heads, 72cc chambers
•Crane Energizer Hyd Cam & Lifters .454/.454 Lift, 216/216 duration @ .05
•Speed Pro hardened Pushrods
•Summit long slot 1.5R stamped steel rockers
•Edelbrock Perform dual-plane intake #3701
•Accel Performance Replacement HEI with custom advance curve
•Taylor Spiro Pro 8mm Wires with MSD 'twist-on' 2-wire separators, OEM metal shrouding (wires routed under headers like OEM)
•LARS-rebuilt/tuned Qjet #1904
•OEM 5 qt oil pan (stock baffles)
•100amp alternator, starter, replacement water pump and 7-year low-maint. battery from Western/Advance Auto
Transmission:
•Bow-Tie Overdrives 'Stage 2' 700R4
•1800rpm stall converter
Exhaust:
•Heddman #68301 Jet-Hot Ceramic Coated 1 5/8" tube headers with 3" collectors
•Full Dual 2.5" Mandrel Bent Pipes with H-Pipe
•No catalytic converter
•Dynomax Super Turbo mufflers
Suspension:
•3.54 Spicer gears in blueprinted replacement DANA44 by Alan's GearWorks, Clearwater, FL
•Stock gymkana front/rear spring rates)
•KYB GR2 shocks on front/Gas-a-just on rear
•Van-Steel rebuilt half-shafts with stock u-joints
•Stock gymkana front/rear sway bars
•Stock 15" '80 Corvette aluminum wheels
•GoodYear Eagle GT II P255/60R15's at all four corners
•VB&P Rebuilt Front Power-steering system (pumps, cylinder, hoses, etc.)
•VB&P Federal Mogul Rubber suspension @ front/rear
•VB&P Poly-adjustable rear strut rods
•Van-Steel rebuilt rear trailing arm assemblies
•Precision Shaft Technologies shortened/balanced driveshaft (for 700R4 conversion)
Misc:
•Re-cored Modine radiator from Advance Auto (local shop re-cored it in 2008). OEM clutch-style flex fan
•semi-metallic Brake Pads (possibly RayBestos)
•SuperTech 20W50 oil in engine
Rear wheel dyno performance from approx 2002:
225rwhp/289rwtq in 3rd gear (1:1)
when we can...
but I agree.... someone should try and start a thread on that though... think it would be very cool.....
nothing but love bro....
