Diff. crossmember reinforcement kit
Old Apr 2, 2010 | 07:49 PM
2box's Avatar
2box
Default Diff. crossmember reinforcement kit
I am in the process of rebuilding the rear suspension on my 79 and I am wondering if You guys have any experience with this aluminum oversize washers, lol, I want to know if they'r worth installing as allways any help is greatly appreciated....
Old Apr 2, 2010 | 08:43 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Solid diff x-member locating kit. If you tend to push hard on occasion but don't want to go so far as to eliminate the bushings altogether IMCO you should get one. I prefer a 3 piece kit which includes a disk for the pinion support bracket.
Old Apr 6, 2010 | 07:50 PM
2box's Avatar
2box
Old Apr 6, 2010 | 10:50 PM
TheSkunkWorks
If we're talking about the same thing, to quote Guldstrand, those [aluminum oversize washers] "help eliminate crossmember movement caused by large tires, high cornering loads and engine torque."
Old Apr 8, 2010 | 10:58 PM
2box's Avatar
2box
Have You used them before? and Do they really work? I do have 15" rims and large tires.
Thanks..
Old Apr 8, 2010 | 11:22 PM
True Blue Vette's Avatar
True Blue Vette
I have to say, it's worth the pocket change to better locate your diff. The factory style rubber differential crossmember mounts allow your entire rear suspension to move and change geometry since the differential IS the control arm mounting point. Great for selling a quiet, soft riding car, not so much if you like corners.
Old Apr 8, 2010 | 11:30 PM
2box's Avatar
2box
Let me understand this a litlle better.. They are used with the old bushings in place right. And once You install them You get better handling and still a smoth quiet ride right.
Thanks...
Old Apr 8, 2010 | 11:37 PM
True Blue Vette
I can't say much about street car parts, but I can say if it keeps your differential still, it's a good thing. I would solid mount it, were it mine. -Jeff
Old Apr 9, 2010 | 05:53 AM
gkull's Avatar
gkull
The al disks solved my wheel hop problems
Old Apr 9, 2010 | 10:58 AM
TheSkunkWorks
Yes, I've had them on my shark for ages and satisfied that they help a lot.
Eliminating the bushings (on my do list) is IMCO best considered a hardcore type mod, but if that's where you're going with it I have the dimensions of the bits you'll need to have fabbed up.
Old Apr 9, 2010 | 08:45 PM
2box's Avatar
2box
Thanks a lot guys. You have helped me made up my mind.. I ordered them for $45.00.
Old Mar 24, 2014 | 01:00 PM
Lrayzer's Avatar
Lrayzer
1st Gear
I am just searching around, in the process of redoing a 78 Vette, really want to eliminate that rubber bushing, very surprised no poly or alum bushings are out there, but I have access to a machine shop if you can e-mail me the dimensions, I was thinking of a welded in shock bar and replacement diff mount possibly.
Old Apr 29, 2015 | 05:03 PM
bbeck's Avatar
bbeck
Did you go with the solid aluminum?
Any feedback on how it is after?
I'm looking over my options to do this over the next couple of weekends.
Old May 1, 2015 | 11:57 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I've never seen any poly mounts available, but you could fabricate your own with some work. I did it about 10 years ago. Made them from polyurethane casters and cut out the wheel ending up with round poly bushings that I compressed with a steel plate. I also used the aluminum disks to help hold everything together.
Did this when I moved the differential crossmember up relative to the frame to improve geometry. Nothing too tricky but it wasn't an easy job.
To Diff. crossmember reinforcement kit
