Brake booster filter
Old Apr 2, 2010 | 09:44 PM
80vette21's Avatar
80vette21
Default Brake booster filter
Is the canister filter that is stock in the vacuum line from the carb to the brake booster necessary?
During my motor swap my old one somehow got misplaced and Im wondering if its worth spending the $30 on a new one.
What does it do, keep crap like carbon from building up in the booster?
I appreciate any input.
Old Apr 2, 2010 | 09:52 PM
TPI BOY's Avatar
TPI BOY
Old Apr 2, 2010 | 10:18 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I pitched mine about 5 years ago and haven't had any problems.
Old Apr 2, 2010 | 10:40 PM
terry82's Avatar
terry82
they keep the bad fumes from inside the motor from getting into the brake booster. thats what i was told .i replaced mine with one from autozone and it was only a few dollars .
Old Apr 2, 2010 | 11:12 PM
tonak's Avatar
tonak
http://www.autozone.com/autozone/cat...Booster+Filter
6.99
Old Apr 3, 2010 | 08:00 AM
Duke94's Avatar
Duke94
Correct, GM had a big recall in the 70's to add this charcoal filter. Intake manifold gas fumes got into the booster and destroyed it. It should be mounted vertically to work correctly.
Gary
Old Apr 3, 2010 | 11:27 AM
80vette21's Avatar
80vette21
yeah, I figured it was meant to keep carbon and other harmful fumes from building up in the booster and causing issues with the power brakes.
Thanks for the cheaper solution! I had checked my local parts place and they didnt have it, but Ill check my local autozone and see if they have it in stock.
To Brake booster filter
