1968-BB spark plug wires ?
Old Mar 13, 2002 | 01:06 PM
verskel's Avatar
verskel
Default 1968-BB spark plug wires ?
Ok, had a little problem last night :eek:
My Accel 8mm wires were falling apart.....heat ? :mad
Anyways, one wire blew apart (while driving) check under the hood,
went to change the plugs and another boot tore in half -ouch-
So here's my dilemma :
My block is a '70s model (396, 454 ?) and it has R45TS plugs, orig. coil ignition system (points), so what aftermarket wires can I use that will last ?
Right now (temporary), I'm using a few Borg-Warner 7mm wires in place of the broken ones - :U
Taylor wires ??? ...what are you guys using ??? :hat
Old Mar 13, 2002 | 10:04 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: 1968-BB spark plug wires ? (verskel)
I had the same problem with the premium MSD wires. I went through two sets and then bought the Ceramic booted wires from Jacobs. They cost 3 times as much, but they are guaranteed for life and I have not had any more problems.
Chuck
[Modified by Chuck Harmon, 6:05 PM 3/13/2002]
Old Mar 14, 2002 | 07:06 PM
jpread's Avatar
jpread
Saw a set of sheilded Delco wires on Ebay today. Supposed to be NOS.
They were in the $45 range.
I think they were for a 67 but should fit 68.
Old Mar 14, 2002 | 09:19 PM
kostutsman's Avatar
kostutsman
Use 8mm Accel High Temp Super Stock - no problem
kos
To 1968-BB spark plug wires ?
