Holley Street Dominator - BBC application
Old Apr 4, 2010 | 08:48 AM
carbster09's Avatar
carbster09
Default Holley Street Dominator - BBC application
Just heard from the engine builder that my old intake needs a little "too" much work. So, a hunt on fleabay turned up an "old" Holley Street Dominator for a BBC. I took a chance and did the buy it now. We'll see what it looks like when it gets "home".
Are there any details that I need to know about fitting it to my "stock" looking LS 5 when it is rebuilt? I run the stock BB hood. Do I need to run a different air cleaner?
What about any real HP improvements? We will have a look at porting it and it will be port matched. Any recommendations for ... coatings, or even something entirely too costly like extrude honing?
BTW this is going on a somewhat moded ... LS 5 with a forged 489 assy; Crower crank etc .. it should be nice.
carbster09
Old Apr 4, 2010 | 05:26 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Which one? If it's the med-rise oval port dual plane one, without extensive work it's going to be done by ~5200 rpm anyway. Should that be enough, I'd just do a standard port match (to the heads, not the gaskets). Sorry, don't know what you'd have to do for hood clearance, but suspect a dropped base and perhaps 2" filter might be necessary.
An option you might be interested in, especially if OEM appearing kit is to your liking, is that you could always match an alum LS6 intake down to oval port heads with some epoxy, as another CF'er has done...
Old Apr 4, 2010 | 05:48 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I have seen myself a '72 BB that had a Holley street dominator intake with a Holley carb and 2 in. air cleaner all under a stock BB hood, so I'm quite sure it will fit OK, it seems they used something similar to the LT-1 dropped air cleaner base.
I have the same intake and I compared it to the stock dual plane one and the Holley is at least 3/4 in. higher.
Old Apr 5, 2010 | 12:01 AM
carbster09's Avatar
carbster09
Default L 88 hood?
So are you running an L 88 hood there in Doha?
I suspected that I needed something like an LT 1 air cleaner... thanks for the input.
Do you think there is much to gain with an LS 6 intake port matched? It seems like alot of work; however I am willing to do it. Or try to find someone. I wanted to appear stock or stockish but the old L 79 intake is not the best and my stock LS 5 ... might not fit the bill.
Do you reckon the Holley street dom gives me anything over the stock LS 5? Other than the weight issue of course.
Someone really needs to design a decent intake to take advantage of this ... I was hopeful the Weiand Stealth would fit; but it doesn't.
carbster
Old Apr 5, 2010 | 02:43 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
carbster
No the '72 used a stock BB hood not the L88 hood. I'm not sure about the LT-1 air cleaner but since the difference in size I do think it may need it.
Personally, I can't see where the LS6 intake would give any improvement versus the stock LS5 one, both of them are low rise and dual plane, while the street dominator is a little taller and its a single plenum which will help in mid-high RPM range.
I just picked a LT-1 dropped base from ebay and if it will fit my stock BB hood I would give that intake a try and compare it with the stock one back to back.
Old Apr 5, 2010 | 06:35 PM
TheSkunkWorks
LS5 intake is iron, LS6 intake is aluminum.
Old Apr 6, 2010 | 12:56 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
It may help to make things a little lighter, but if he will convert it into oval port style he will end up with just another LS5 intake except its made of aluminum.
Old Apr 6, 2010 | 03:33 PM
Lester B's Avatar
Lester B
Just a note, having just fitted a 454, if I fit a 2 inch or 2.5 inch air cleaner it hesitates abouve 2,000 rpm with no load and even worse when driving - fine under full throttle when the secondaries open. Fit a 3 inch and its all good. It needs alot of air, and certainly mine doesnt breath properly with anything under a 3 inch air cleaner.
Just my two cents.
Lester
Old Apr 7, 2010 | 02:10 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Just my two cents.
Lester
Thats the common problem when using anything less than 3 in. air cleaner, anything smaller will get the lid closer to the choke horn and will almost block it which will cause what you described, you can either cut off the choke horn and sacrifice the choke or use a taller filter.
Old Apr 7, 2010 | 02:12 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Yesterday I receiver the LT-1 air cleaner base, its much deeper than what I have now. I made some measurement and it appeared that it would work great with the Holley street dominator intake, the base is 3/4 in. deeper and the carb base on the street dominator is 3/4 in. higher, so you'll end up with exactly the same 3 in. air cleaner height as the stock LS5 intake, which is a very good news.
Old Apr 7, 2010 | 09:13 AM
carbster09's Avatar
carbster09
Default thanks
Thanks for the input. The old fleabay special holley street dominator is on its way! I am debating, extrude hone, acid port or just send it off to the builder ....
Old Apr 7, 2010 | 05:40 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I'm sure you'll love it, I was surprised with the quality of these old intakes, too bad they don't make them anymore! .. I will try to install my ASAP as I'm really curious to do a comparison.
Old Apr 8, 2010 | 05:25 PM
Superstock's Avatar
Superstock
I have run the 300-3 single plane Holley Street dominator on my 73' 454 950HP with summit G-3000 . Comes with 1 1/4" drop base , 3" filter , and chrome top ( $21.95. )I do have my choke tower milled off and have shortened the bowl vents .
To Holley Street Dominator - BBC application
