Gas color-orange
Old Apr 4, 2010 | 04:43 PM
ssenay72's Avatar
ssenay72
Default Gas color-orange
The gas in my car is what was there when i bought it a few months ago. Drive it home and started to tear it down right away. I noticed the gas color is more orange than usual. What is that???
Old Apr 4, 2010 | 05:34 PM
oldsarge's Avatar
oldsarge
The gas has either had a additive put in it or it has gone bad. Old gas will turn yellow or slight orange and loose its octane. Probably best to get it out and put in some fresh gas.
Old Apr 4, 2010 | 09:40 PM
OMF's Avatar
OMF
Just receintly I drained some fuel from a '68 Charger rebuild project, and the gas from that tank was orange also.
I'd drain and flush as best you can.
Old Apr 4, 2010 | 10:36 PM
ssenay72's Avatar
ssenay72
ok so the easiest way on a 1975 would be? siphon? open the line??
Old Apr 5, 2010 | 04:59 AM
RunningMan373's Avatar
RunningMan373
i believe that gas is died orange from the refinery. believe they do it so they can tell what it is, later.
Old Apr 5, 2010 | 10:40 AM
tomgallucci57's Avatar
tomgallucci57
hope its not rust,the gas cans i have for the lawn mower have been sitting around longer than the gas in my 68,and there still blueish color. but my vettes gas is also yellow orandeish,but i do add sta bil to it for the winter time,i also have a rust issue. the only reason i know that ,is the old owner had put on a clear fuel filter and i could rust in it. so i change them often, theres also a filter near the tank,, ill be replaceing the tank soon. good luck tom
Old Apr 5, 2010 | 10:45 AM
tomgallucci57
ps i also put a shut-off valve near the tank so i could change filters without getting wet.it would also serve as a drain valve.
Old Apr 5, 2010 | 10:58 AM
ssenay72's Avatar
ssenay72
Can you post some pics or explain how you did the shut off valve? That seems like a good idea. I might change the fuel lines anyway. How hard is the tank to take out?
Old Apr 5, 2010 | 11:41 AM
tomgallucci57
my car came to me with a foot and a half of rubber hose coming off the tank , so i used vise gripes to clamp off the hose so it wouldnt drip on me. actually i got drenched the first time and my arms turned purple from the gas sucking into the sweatshirt i had on. but , vise grip the hose nearest the tank as possible to stop the gas flow then insert a fuel line shutoff valve, which i could only find in 3/8 th. in. at a store called parker, which is affilated with parker hannifan who makes all kinds of valves etc.,, it was easy for me because i already had some rubber line to work with, i understand you have to take off the rear sections of the exhaust system to lower the tank itself, but may not be terribaly hard to do, im not at that point yet,,,, tom
To Gas color-orange
