Does anyone know what the diameter of the original F70-15 tires on 68 Corvettes was?
I would like to know the diameter because the speedo gears in the transmission are probably
calibrated for the original tire size. Therefore - when using another tire diameter -
your speedo will be slightly off. I would like to calculate exactly by how much the speedo
would be off on my Vette. The diameter of my 255/60R15 tires is 27.1 inches!
You can also check speedo error by driving between mile markers on the highway. Go ten miles and record the odometer at the begining and end. Do the math and get the results. If it reads 9miles then yur 10% off to slow...ect..
Remember with speedo errors, the margine of error get wider the faster you go. Its still 0 at 0. Are you confused yet?? :lol:
According to Richard Newton's "How to Restore and Modify your Corvette 1968-82." All 'Vettes prior to '78 came with a tire called GR70 that was 27.1" tall, a specification matched by your current setup.
thats true if nobody ever changed the speedo gear. Mine was right on with a 28 " tire/
Do your damnedest to go 60 and get a stopwatch or just a watch with a second hand. Note how long it takes to go by mile markers on an interstate. Go more than one mile and average, since the markers are not always perfectly placed.
Figure your actual miles per hour by dividing the seconds it takes to go one mile into 3600.
Put another way: 3600 / seconds-per-mile = miles per hour.
If it's close to 60 your speedo is good to go. Going one tooth higher or lower in the speedo gear changes the calibration by about 5%.
>>slow...ect..
I tried to check my speedo already between milemarkers. approx. 10.15 miles on my odometer = 10 1-mile markers, which would mean that my speedo is 1.5% off!
What I am trying to find out with this thread is if those 1.5% result from a 1.5% lower diameter of my current tires or if the odometer is responsible for the inaccuracy (or maybe the gears in the tranny)
Thank you for the information!!
Olivier
P.S. still wondering about my 1.5% difference (see prevous reply)
Just guessing, but 1.5% may be well within the design tolerance. Like I said, the speedo gears give about a 5% jump for each size.
I think most folks would be happy to be within 1.5%. My speedo reads about 15% slow, something I plan to do something about one of these days, after I get my new wheels and tires.
1.5% error is very close to right on. Thats only .9mph off at 60mph and 1.5mph off at 100mph. Thats so close that even low tire pressure could account for the error.
Replacing the stock speedometer with Autometer Phantom Speedometer made a gret difference in accuracy! The stock speedo was off at least 5 - 6 %!!!
