Speedo cable removed from Tranny
Old Mar 13, 2002 | 06:14 PM
BB68Vett's Avatar
BB68Vett
Default Speedo cable removed from Tranny
Now my transmission leaks gear oil (Manual 4 speed). Any way to plug the hole in tranny until I get a replacement cable?
Old Mar 13, 2002 | 07:50 PM
R. Bruno's Avatar
R. Bruno
Default Re: Speedo cable removed from Tranny (BB68Vett)
Where exactly is the leak? Are you sure it is not the o-ring on the housing for the speedo gear?
Old Mar 14, 2002 | 01:10 PM
BB68Vett's Avatar
BB68Vett
Default Re: Speedo cable removed from Tranny (R. Bruno)
Since I had no leak before I removed the cable, I presume it is because (as I understand) transmission oil is splashed up in that area and without the cable it leaks out. Any ideas anyone?
Old Mar 14, 2002 | 01:52 PM
R. Bruno's Avatar
R. Bruno
Oh- now I get it. The housing is present but cable is removed. Sorry- no ideas.
Old Mar 14, 2002 | 01:56 PM
MikeC's Avatar
MikeC
Sounds like one of the orings in the speedo gear housing is worn out. Pull the housing out and check whether the gear shaft is worn out or the o-ring that seals it. Replace wither or both and it should be good.
To Speedo cable removed from Tranny
