Stripped tooth on ring gear
Old Apr 6, 2010 | 08:42 AM
Aussie79's Avatar
Aussie79
Default Stripped tooth on ring gear
ok, so how hard is it to remove and replace a ring gear or do I put up with that embarrasing once in a while scream from the starter motor?
Whats easier, dropping the transmission (auto) or engine to access it?
Once out how hard is it to put a new gear on the flywheel?
Thanks, Dennis.
Old Apr 6, 2010 | 10:01 AM
MelWff's Avatar
MelWff
You loosen the transmission and push it back. You dont have a flywheel you have a flex plate and it is serviced as a complete assembly.
Old Apr 6, 2010 | 11:15 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You don't need to completely remove the trans, just unbolt the torque converter and the trans and push it back far enough to get to the flexplate bolts.
Old Apr 6, 2010 | 12:09 PM
spookytooth's Avatar
spookytooth
If you take the spark plugs out you should be able to rotate
the motor and get to all the bolts.
Old Apr 6, 2010 | 01:34 PM
OMF's Avatar
OMF
What everyone here is telling you....replace the flexplate with a new one. The damage on your existing one will only get worse with time, and eventually leave you stranded. It's not hard to do if you have mechanical skills
Old Apr 6, 2010 | 03:50 PM
Kelso's Avatar
Kelso
This may be a little of a bubba trick but you can drop the insepction cover below the flex plate turn the engine over until you can see the stripped or broken tooth and put a good weld in the area and file it back to the correct tooth shape.
Yes, this is bubba but it saved us a the track one night. !
Old Apr 6, 2010 | 04:51 PM
Paul L's Avatar
Paul L
Good tip!
Old Apr 6, 2010 | 05:25 PM
Lovethatvette's Avatar
Lovethatvette
Cruising
Hi Aussie -
Just done this very job myself - and its not a barrel of laughs it must be said !!. Very tight squeeze.
If you search on here for "MrGofaster" you'll find a thread he's posted on how he tackled this job on his car - complete with a video - very bloody useful !!.
Best of luck with it.
Laurence
Old Apr 6, 2010 | 05:30 PM
TERRY CLARK's Avatar
TERRY CLARK
Bubba or not it will save a ton of work...........and if done right, it's good as new!
To Stripped tooth on ring gear
