Driveshaft loop on C3's ?
Old Mar 13, 2002 | 09:30 PM
467-Ratman's Avatar
467-Ratman
Default Driveshaft loop on C3's ?
Is it possible to install a Lakewood drive shaft loop on our cars for protection? What does it bolt to, the frame? Don't want my driveshaft to take a @#@$ and fall off or rip up the bottom of the car!
Old Mar 13, 2002 | 09:59 PM
Clink69's Avatar
Clink69
Default Re: Driveshaft loop on C3's ? (467-Ratman)
I want one also. I know people have done it..
:flag
Old Mar 14, 2002 | 09:23 AM
Noel Carboni's Avatar
Noel Carboni
Given that the shaft is fairly captive in there, do you really need one?
If the front U joint broke the shaft end will be kept above the crossmember, I think, so you're not going to have it spear down into the road and cause that kind of havok. If the rear joint goes the shaft is held above the frame dip back there.
Is the shaft likely to turn into a wild and dangerous fan with the tranny tunnel keeping it generally in place? Can't say I have any experience with driveshaft failure, though I have broken half shaft U-joints.
-Noel
Old Mar 14, 2002 | 09:34 AM
norvalwilhelm's Avatar
norvalwilhelm
I have one on my drive shaft and untill I built my 6 link this winter had 2 on each half shaft. Mine is bolted through the floor with 8 5/16 bolts welded to two plates under the carpet, seat.
Mine is made of aluminum and shows in this picture.
Old Mar 14, 2002 | 11:20 AM
StingrayRacing's Avatar
StingrayRacing
Default Re: Driveshaft loop on C3's ? (Noel Carboni)
Noel,
I agree with you...but will the NHRA agree with us?
To Driveshaft loop on C3's ?
