Rebuild or Replace
Old Apr 10, 2010 | 01:11 AM
Korevette's Avatar
Korevette
Default Rebuild or Replace
Just left the local radiator shop discussing my 1976 4 core copper rad. Was quoted $415.00 dollars for a brand new core and tank swap.
I am stuck between replacing new with after market or a rebuild. It is an original Harrison rad.
Your comments and advice are appreciated.
Dano,
Old Apr 10, 2010 | 03:33 AM
Golden's Avatar
Golden
This is a hard question as a lot of it comes down to how good your rad shop are.
I've had rads rebuilt and they've been nicer than a new reproduction but some peoples reconditioned units I've seen look like a bubba recon.
Old Apr 10, 2010 | 10:18 AM
markids77's Avatar
markids77
Many here report great success with aluminum radiators as an upgrade. Your quoted recore price approaches the cost of a "premium" aluminum unit, and exceeds the cost of a couple "brand x" units which several forum members have recommended as excellent. I have also seen all copper/brass new rads on eBay advertised for similar dollars. On my 1977 I will try one of the "brand x" units which got multiple positive ratings in various posts. Then again, if the Harrison logo on the tanks is important for you, unless you can find NOS, a recore is the best solution.
Old Apr 10, 2010 | 10:35 AM
terrible_buddhist's Avatar
terrible_buddhist
personally, I would take the radiator home, drain it, wrap it in plastic and store it. Then take that money and put it towards an aluminum rad with electric fans. But that is just me.
Old Apr 10, 2010 | 10:46 AM
71coupe454's Avatar
71coupe454
I had my Harrison radiator recored with some kind of better material and it looks great, but my shop only charged me like 295 for it..
Old Apr 10, 2010 | 10:54 AM
71406's Avatar
71406
While I haven't shopped recently for a re-core at a radiator shop, the price sounds high. I had mine recored when I installed a new motor. A local shop installed a new core using my original tanks. While the core was new, it's shape was not the exactly the same as the original. For this reason I had a hard time properly installing the upper and lower radiator seals. When I was done it looked like Bubba was there helping me. Even thought I got it to seal, I soon discovered my new motor required a little more cooling than stock so I purchased a DeWitts exact fit aluminum radiator. Not only was it an exact fit but it brought more cooling efficiency than a newly recored radiator from a local shop. To make this long story short, if I was going to spend $415 on a radiator I would look and see what DeWitt has to offer for your vehicle. Good luck.
Old Apr 10, 2010 | 11:20 AM
tfi racing's Avatar
tfi racing
That's not all that bad.Around here last summer I was quoted anywhere from 700 to 900 bucks for a recore.New brass/copper rads weren't available then for some reason,so I ended up using a place on the mainland for $450.Unless you want to keep it very original,I would just get a new one or if you have a few extra to spend I would recommend an aluminum unit from DeWitt.
Old Apr 10, 2010 | 12:21 PM
Jeff_Keryk's Avatar
Jeff_Keryk
If you want to keep your car to be original, get your Harrison recored. My Dad worked at Harrison Radiator in the late 50's... Check around for a good price, but make sure you get quality. Otherwise, there are a lot of radiators out there. Aluminum with their larger tubes are great and so are good 4 row radiators.
Old Apr 10, 2010 | 12:23 PM
Mark G's Avatar
Mark G
Yeah, I kinda wonder if you get a new tank, then is it a "Harrison" radiator. Does it leak or is it plugged? If you are going for a totally stock car, then find out what the new tank will look like (EXACTLY). Will the markings be removed. If that's the case you gotta wonder if you've already tipped the scales of originality.
OTOH, if originality is important, but not highly critical, going with a repro radiator and keeping your original (for the next owner), may be a viable option. I'm trying to keep my car as original as possible so for me it would come down to how original the repaired radiator would be vs. the cost and apearance of a replacement be it aluminum or copper. I see your dilema. Good luck,
Mark G
Old Apr 10, 2010 | 01:36 PM
Korevette's Avatar
Korevette
Thank you all for the great advice.
Further inspection shows the rad was repaired at one time. The tanks were off before. I also observed the left lower side of the tank was deformed as if it was 'beat in'. It appeared someone forced the rad in position. There were no leaks at this location. The rad is a 27 1/2 inch 4 core. It would be very tight to begin with. I do have air conditioning as well.
Please list vendor(s) that would provide a quality product that will fit exactly?
Dano,
Old Apr 10, 2010 | 02:22 PM
John Dingman's Avatar
John Dingman
Dano,
Hi Dano, This is our direct fit aluminum radiator, part #A73A for auto, or A73M for manual. We also offer it with black ice epoxy coating, this makes it look very close to original. The aluminum radiator in the same size as the copper will offer 30% more cooling.
Having a local radiator shop recore your radiator is a fine idea, but unless they use our copper/brass core it will still be wrong as far as looks. We are the only company that sell a correct copper brass core. For the money I would go with the aluminum direct fit. Keep the tanks off your original radiator. You'll be happy with the looks and performance.
John
http://www.dewitts.com/pages/product...asp?ProdID=281
Old Apr 16, 2010 | 11:57 PM
Korevette's Avatar
Korevette
After much review of others posts on this website and some outsourcing I deceided to order a DeWitts Direct Fit rad for my 1976 4 speed. I have found this website invaluable as it assited in my purchase. I thank you all for your present and past experiences.
Dano,
To Rebuild or Replace
