leaking proportioning valve
Old Apr 11, 2010 | 03:16 PM
curtis75's Avatar
curtis75
Default leaking proportioning valve
I put all new brake lines on my 75, I went to bleed them and the proportioning valve was leaking. I tightened all the lines up and tried again, still leaking. found that the leak was coming from the actual valve. I took a picture of the part that was leaking and found a little hole in the side of it. I'm not sure why its there or what it does but I think its leaking from there. Can anyone help. thanks
This is the outlet for the rear brakes
Old Apr 11, 2010 | 06:06 PM
Duke94's Avatar
Duke94
That's a vent for the atmospheric cavity inside the hex plug. There is a spool with 2 o'rings on it, one or both are leaking. The assembly is pressed together and can not be taken apart.
Gary
Old Apr 11, 2010 | 06:15 PM
curtis75's Avatar
curtis75
so I guess I need a new one, can I buy just it or do I need to get a whole proportioning valve?
Old Apr 11, 2010 | 07:21 PM
fogaley's Avatar
fogaley
I took a customers apart, installed three new orings and it works fine. Scott
Old Apr 11, 2010 | 07:22 PM
Duke94's Avatar
Duke94
You can only buy the complete assembly.
Gary
Old Apr 11, 2010 | 07:23 PM
Duke94's Avatar
Duke94
How did you get the pressed in end cap out without damage?
Gary
Old Apr 12, 2010 | 07:58 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Gary
Old Apr 12, 2010 | 05:14 PM
curtis75's Avatar
curtis75
maybe if you heat up the outside while you press it out, if your replacing the o-rings anyway. Can you use normal o-rings for brake fluid or do you need special ones.
Old Apr 12, 2010 | 05:31 PM
pauldana's Avatar
pauldana
$60 ecklers: http://www.ecklers.com/product.asp?p...ept%5Fid=1050#
Old Apr 12, 2010 | 07:35 PM
Duke94's Avatar
Duke94
Perhaps poster fogaley was referring to the 2 o'rings on the diff piston and the one on the end plug as shown in this photo, they are easy to change. I hope he reports back so we all know.
Gary
Old Apr 12, 2010 | 08:05 PM
ref772's Avatar
ref772
Do not use normal o'rings. They must be ethlyene propalene. Please excuse the spelling. I think it's correct. E-P is compatible with brake fluid. Nitrile is not.
Old Apr 12, 2010 | 08:09 PM
ref772's Avatar
ref772
Sorry, forgot to mention that about the only place to get E-P o'rings is from someone who rebuilds master cylinders or hydro-boost / brake boosters.
Old Apr 12, 2010 | 08:27 PM
Duke94's Avatar
Duke94
DON"T buy hardware store o'rings. Many towns have commercial parts supplers (Rodger Zatkoff is ours in Detroit) that sell o'rings of the correct compound and hardness. You can Google 'O'rings and the city you live in to find them. You might have to buy 25 bucks worth (which would be enough to rebuild a 100 valves).
Gary
Old Jul 10, 2010 | 07:58 PM
Duke94's Avatar
Duke94
Thanks to a fellow Forum member who donated his used valve to the cause, I was able to get it apart with no problem. Use a 1/8" diameter dowel pin (about 2" long) and insert it in the outlet port (see photo below) and press the retainer out by supporting the end plug with a 3/4" socket. I used a press, but a vise will do as it didn't take much force to push it apart. The last photo shows what the parts inside look like. I could probably do some type of WORD document showing how the whole thing comes apart and what's needed to rebuild it if anyone would be interested.
Gary
Old Jul 10, 2010 | 08:30 PM
...Roger...'s Avatar
...Roger...
Duke are you sure the internal o rings are what is causing the external vent to leak ?
Old Jul 10, 2010 | 08:59 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sometimes you gotta bite the bullet and buy a new one, that's what I did and should last another 30-100 years who knows I'll be long gone. I f'upped the threads installing new brake lines otherwise the original block would still be in there
Old Jul 11, 2010 | 08:59 AM
Duke94's Avatar
Duke94
[QUOTE=...Roger...;1574656182]Duke are you sure the internal o rings are what is causing the external vent to leak ?
QUOTE]
Yes, the spool inside the end plug has an o'ring at each end with the spring in an atmospheric chamber in between. The spool moves with each brake apply (above the knee point of the valve when it starts to proportion) so if either one of the o'rings wears out, brake fluid leaks into the this cavity which eventually blows out the dirt seal on the side of the hex plug and fluid leaks on the ground.
Gary
To leaking proportioning valve
Old Jul 11, 2010 | 09:17 AM
TeaEye's Avatar
TeaEye
Gary,
I'm game. I have two of these in my garage which the "inside" o-rings have disintegrated. Needed the O-ring tip! Thanks. I have two sets of O-rings. See photos -- would any of these work? The green ones are for AC units and the label on the black ones says for hydraulics?
Would love to see a word document so I can replace mine and finally get that light out.
Pauldana: Couldn't get your link to work -- what item is $60.?
Motorhead: I agree sometimes you have to bite the bullet. However, love fix'in things TOO as long as we mitigate the risk of a catastrophic failure. Does anyone see the potential for "a brake fluid blow -out?"
TI
Old Jul 11, 2010 | 11:13 AM
Duke94's Avatar
Duke94
Originally Posted by TeaEye
Gary,
TI
For sure the green ones won't work since they are NBR compound and are not compatible with brake fluid. I'd guess that the other isn't either as I think the "Hydraulics" referred to is hydraulic jack oil (mineraloil based) NOT brake fluid. O'rings need to be EPDM material to work with BF.
Gary
Old Jul 11, 2010 | 12:50 PM
...Roger...
[QUOTE=Duke94;1574659546]
QUOTE]
Gary
Thanks , thats nice to know.
