set timing with computer car
Old Apr 11, 2010 | 10:56 PM
dburgjohn's Avatar
dburgjohn
Default set timing with computer car
before the computer you unpluged the vacume hose to the distributor before setting the timing. What do you do on a 81 with the computer controled distributor?
Old Apr 12, 2010 | 05:19 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Default Timing
Unplug the 4 wire connector to the Distributor and set the base timing.
Hope this helps set it about 12 degrees and if it pings back off a wee bit
Ken
Old Apr 12, 2010 | 10:13 PM
dburgjohn's Avatar
dburgjohn
Default 4-wire plug?
Tried that, car would not start with that plug off.
Ken
Old Apr 12, 2010 | 10:53 PM
...Roger...'s Avatar
...Roger...
Sounds like unplugged the wrong connector.
Old Apr 12, 2010 | 10:55 PM
dburgjohn's Avatar
dburgjohn
Default three plugs
There are three plugs, two single wire (batt and tach) and one four wire. How could I get it wrong?
To set timing with computer car
