No spark
Old Apr 16, 2010 | 03:49 PM
Vesa's Avatar
Vesa
Default No spark
I have driving the vette some days after winter storage with no issues. But now when I started it, it run 10 seconds and died. After that no promises fully dead.
What I did do was some testing: I used a checking pen with light.
1. pen was put between coil + and ground. When cranking the engine the light goes on and off. So maybe the current is flowing inside the coil from MSD box.
2. Coils terminal that is connected to distributor. The pen inside that coil terminal and ground. When cranking - no light. Is the coil the problem?
3. I attached a brand new spark plug into that wire coing from coil to distributor (into the distributor end) and cranking - no spark in plug when plug is place tight on ground. Is the coil the problem?
Well...I bought a new coil and new try, but same situation no spark in a sparg plug test (test nr 3). Also test nr 1 show same result as earlier.
What to do next?
http://www.msdignition.com/instructi...pdf?terms=6421
Page 10 lower picture, I do have that setup with distributor.
Old Apr 16, 2010 | 04:41 PM
terrible_buddhist's Avatar
terrible_buddhist
my thought would be to cut a long wire and try rigging up the ground to a different source...then do the same on the power side to see if it is a bum wire.
Old Apr 17, 2010 | 05:40 AM
Vesa's Avatar
Vesa
I found my volt meter. The cround wire gets full 12v ground. Both + wires suply full 12v and new coil didi not help. And doing that test MSD recommends points out that the BOX is the reason...so **** stuff this digital 6al-2 if 6 months old box dies like this
Old Apr 17, 2010 | 05:49 AM
73StreetRace's Avatar
73StreetRace
Where did you install your 6AL-2 ignition box ?
This kind of stuff is quite sensitive to heat, and there is a lot of heat under a hood, especially near cylinder heads or headers...
Old Apr 17, 2010 | 08:39 AM
Vesa's Avatar
Vesa
That can not have been a problem...I think...the weather has been between 5 and 10 degrees celcius. I mounted in behind right hand side front tire inside the engine compartment side to the lowest possible point. You can actually see it through the fender ventilation hole.
Old Apr 17, 2010 | 08:54 AM
73StreetRace
I'm not so sure about that. Fenders holes are here to evacuate most of the heat generated under hood by the exhaust pipes and hot air coming from the radiator.
So, even if the box is mounted very low, it doesn't mean that it's the "coldest" area.
I mounted mine in front of the radiator, about 10" behind the front license plate. This is a really cold place and even the rain won't be a problem.
I did this after a bad experience similar to yours... but it's a long story...
Old Apr 17, 2010 | 10:37 PM
LT-1 kid's Avatar
LT-1 kid
it sounds like your points got shorted and are fried,replace them and see if that works
Old Apr 18, 2010 | 01:27 AM
Vesa's Avatar
Vesa
I have MSD Pro-billet distributor...can´t find points from there...
Old Apr 18, 2010 | 01:31 AM
Vesa's Avatar
Vesa
Was it 6AL-2 that died from you? Are those weaker, of bad quality compared to old 6AL...
I had 5 years 6AL in exactly same location and no issues, I sold that to a friend 6 months ago and it still runs great.
I have engine oil cooler mounted in same position as your ignition box...
Did you or MSD open the broken unit and validate the unit that was heat the reason? Or bad hangover on monday on assembly line, or bad design quality on the whole series or?
Old Apr 18, 2010 | 01:34 AM
mydejavooo's Avatar
mydejavooo
Could the module have fried...causing "no spark"? There's not a whole lot that could go wrong there, especially since it was running when you parked it. Also make sure the battery wire that feeds the dizzy is in good condition, and fully clipped in. I had the wire come out on mine this weekend, and it did the same thing. Clipped it back in, and it was good to go.
Deja
Old Apr 18, 2010 | 03:20 AM
73StreetRace
My bad experience was with a Matra X-F1 CD Ignition box, not with a MSD. But clearly, its failure was caused by excessive heat.
So this is why when I bought the MSD-6AL, I decided to change the mounting location.
As far as I know, the new 6AL-2 uses digital electronics instead of old-fashioned analogic components and the new electronic diagram is much more complex.
These digital components are also generally more delicate.
I don't mean I'm sure this is the origin of your problems, but it's a possibility. Perhaps the old MSD-6AL could handle higher temperatures...
Maybe you could put a thermometer in the same location as your ignition box, so you could know how hot it is in this place.
Old Apr 21, 2010 | 07:18 AM
Vesa's Avatar
Vesa
Now it is verified by a local dealer with MSD tester and MSD test bench. The 6AL-2 box is dead.
So I will not buy a new similar digital one. I will go back to analog 6AL...
Old Apr 21, 2010 | 11:11 AM
73StreetRace
Mine is 12 years old and is still working perfectly.
But I think you should try the thermometer tip I was speaking about, just in case...
Old Apr 21, 2010 | 03:42 PM
builder's Avatar
builder
Recheck the ground wire.
To No spark
