Suggestions
Old Apr 16, 2010 | 04:36 PM
ahlersprix's Avatar
ahlersprix
2nd Gear
Default Suggestions
So i've been following the forums for a month or so, learning from those of you who are much more knowledgable than myself and i've come up with a few ideas. I'm looking for 300 - 350 hp out of my stock '76 L-48 and this is what i have come up with
To start: keep in mind all of this is open to suggestion if you know a setup that will work out better
Block bored .030 over
Pistons H618CP30 +3.5
Cam shaft/lifters p/n sum-K1103
Headers SUM-G9003
Head Gasket felpro p/n 1094
most likely will recurve timing
stock heads(possibly port) and intake
I am open to suggestions if you think this may or may not work. I have considered vortec heads and a vortec style intake but not sure if it would create more or less power. Let me know what you guys think
Old Apr 27, 2010 | 06:34 PM
ahlersprix's Avatar
ahlersprix
2nd Gear
so, i'm going to go ahead and assume that this is going to work until advised otherwise
Old Apr 27, 2010 | 07:13 PM
jordan89's Avatar
jordan89
You should really think about going with a pair of AFR aluminum heads. Get rid of those old anchors.
Old Apr 27, 2010 | 07:23 PM
Grumpy 427's Avatar
Grumpy 427
My 355 is 9.5-1 compression hyperutectic pistons, dual pattern comp hydraulic cam. We used reworked 882 truck heads, 1.94 int and 1.60exh valves rpm intake and eddy carb. 340 hp 390 tq.
Old Apr 27, 2010 | 07:25 PM
Grumpy 427's Avatar
Grumpy 427
Should add, no need putting on an expensive aluminum head that will flow more air than what the engine needs and will not give you the results you want. Just my .02 Easy to get what you need out of stock cast heads.
To Suggestions
