Holley 4160 TV & throttle cable setup
I just spend half a day browsing all old posts and still am not sure what to get.
The engine is a 350 deluxe crate with a Holley 4160.
I bought all the required brackets for the 4160 (cam & bracket) and installed a GM TV cable which is installed.
Now for the throttle cable : as the 1974 is not available anymore I bought a 75+ cable, which like already mentioned in other posts is too long. (approx 1 inch)
Many have swapped over to Lokar but I reaaally don't feel like taking the GM TV cable out anymore as it is a pain to hook it up transmission side.
Would the Holley bracket (square hole) accept the lokar replacement throttle cable?
The Lokar cable pedal side is a U shaped bracket with a clevis pin. How would this connect to the standard pedal (with the plastic cup) ?
Is the holley bracket a solution? Is it adjustable enough to comensate the longer cable ?
http://www.summitracing.com/parts/HLY-20-112/ + http://www.summitracing.com/parts/HLY-20-119/
Also, currently there are no return springs. If you temporarely fix the cable to the carb bracket, the mechanism doesn't return, so the carb springs are too weak. Is this normal?
Any help is appreciated, as I'm fed up with ordering parts which I can't use
Thanks in advance,
Nick
Below a pic of the setup (just before the GM TV cable was installed)
Nick
