N2O on stock Eng.
Old Apr 18, 2010 | 01:02 PM
Letournour 1850's Avatar
Letournour 1850
Default N2O on stock Eng.
Have a stock 73 , 350 with a auto trans and would like to give it a little more power with out getting into the eng, Have been thinking about a N2O system. How much of a N2O shot can it handle, and how much differance can I expect??
Old Apr 18, 2010 | 01:16 PM
jordan89's Avatar
jordan89
Is it the base 350 or the L82?
Old Apr 18, 2010 | 02:32 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Don't know anything about n2o, but would think a 50 or 75 shot would be ok.
I just watched Horsepower tv, and they added an 80 shot to a 2000's Camero. It dynoed as an extra 40 hp at the wheels. And a 125 shot added 80hp at the wheels.
Old Apr 18, 2010 | 05:21 PM
Letournour 1850
Not sure if it is a L-82 or base how can I tell? do not do any drag race but would like a little more.
Old Apr 18, 2010 | 05:31 PM
Attfay Elleybay
Have you gone dual exhaust and no cats yet?
Old Apr 18, 2010 | 05:33 PM
Letournour 1850
Yes have a Allens 2.5" chambered with headers
Old Apr 18, 2010 | 08:47 PM
ajrothm's Avatar
ajrothm
Assuming your engine is healthy and in good tune, it will easily handle a 125hp shot. The key is having a good fuel system and the correct tune up for nitrous. You need a GOOD fuel pump, a steady 5psi fuel pressure(flowing, not dead head) to the fuel solenoid and keep the timing conservative....maybe 32* total.....that with a cooler heat range plug and the correct jets in the plate and it will live a long, happy life on the spray....even a stock motor.....you just have to keep it from detonating or running lean. You can easily knock 1 sec off of your ET with a 125 shot.....
Nitrous is great if it's setup and maintained right.....but one mistake and you will be rebuilding.... No room for error with nitrous...and ofcourse there is always a chance something could break in the motor, even if everything IS setup right.
Old Apr 18, 2010 | 11:13 PM
Letournour 1850
Thanks for the info think I will try it out.
To N2O on stock Eng.
