different sort of hot start problem.
Old Apr 20, 2010 | 06:58 PM
Bowerss2's Avatar
Bowerss2
Default different sort of hot start problem.
well i see a lot of guys who's starter motors heat soak. My car requires a god awful amount of cranking to start when its hot (or even after it is cool, but was hot). The starter motor cranks just fine, it just takes a lot of time to start.
I figure this is a problem with the gas evaporating out of the bowls. Am i right? it is most notable only after the engine has been run for a long time, and then shut down. Not for quick drives. Will those insulating carb gaskets help at all?
Also i dont know if it is related, but the car stalls under heavy breaking. I have had about 20 different pieces of advice by different people on this problem. I have already checked for vacuum leaks, there are none.
Steve
Old Apr 20, 2010 | 07:38 PM
Gilded_Splinters's Avatar
Gilded_Splinters
The brake stalling is a tough one, but as far as the starting goes - prime it (carefully) when it's hot and reluctant to start. If it starts right up, you at least have a direction to head in.
I'd look at the float level (S) too.
Old Apr 20, 2010 | 07:49 PM
...Roger...'s Avatar
...Roger...
Do you have a Pertronix conversion?
Old Apr 21, 2010 | 12:49 PM
Bowerss2's Avatar
Bowerss2
i am thinking it all may be related to the floats, im going to check it out this weekend. Any other suggestions?
Old Apr 21, 2010 | 01:41 PM
...Roger...
If you would have said yes to the pertronix I would have cautioned you on some of their units when starting you need to pause the key in the on position for a second or two before turning further to the start position otherwise the engine cranks several seconds longer before firing up.
Have you determined you do have spark while cranking , as the above post says prime and try starting. If it starts its not getting fuel.
When it does finally fire up does the it smoke ?
Floats too high could cause flooding on a hot engine and stalling on braking.
Old Apr 22, 2010 | 06:23 PM
Bowerss2's Avatar
Bowerss2
nope, stock hei
ya i have spark when cranking. no smoke when it does fire up, i will try priming the heck out of it first.
Old Apr 23, 2010 | 12:23 PM
Bowerss2's Avatar
Bowerss2
going to give it one last bump
Old Apr 23, 2010 | 05:43 PM
71406's Avatar
71406
All great ideas above. Some additional ideas...
It may be flooding when you turn it off hot. I'm far from a carb expert, but maybe if boiling over, or maybe dripping well plugs, or maybe a high float level. It would be interesting to see of pumping gas will help (as mentioned in a prior post) or holding foot to floor will help starting when hot. If starting is helped by holding foot to floor its most likely flooding.
As another diagnostic tool, when its not starting look down the carb to see if any gas is entering the carb when you pump the gas. If fuel is not squirting out it could be a few different things. While its pretty remote you could also have vapor lock.
And lastly, be sure your choke is open with you're trying to restart hot. Stanger things have happened. Worth a look.
My guess is its the float.
Old Apr 23, 2010 | 07:37 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
My first guess would be the choke closes too quickly after shutdown causing excessive richness during the hot or warm re-start. Pull the air cleaner the next time you do a hot restart and see if the choke is closed - if it is, manually open it (or have someone hold the choke linkage open); don't press (cycle) the pedal, which would squirt more fuel, but simply hold it down about 1/4 inch, and then crank to see if it starts.
Old Apr 24, 2010 | 01:09 AM
Vesa's Avatar
Vesa
too high rear float level was my problem earlier and adjusting that lower fixed braking stalling problems.
To different sort of hot start problem.
