where do I stick this thing?
Old Apr 20, 2010 | 09:17 PM
terrible_buddhist's Avatar
terrible_buddhist
Default where do I stick this thing?
I have the new radiator all wired up and mounted except for one little thing, the temp switch.
I was going to put it in the head, but I will be damned if I can get the pipe plug out...heat didn't work.
I also can't find any thermostat housings with a 3/8npt hole for a 68 chevy big block.
any suggestions?
Old Apr 20, 2010 | 09:33 PM
Gilded_Splinters's Avatar
Gilded_Splinters
You could drill and tap a hole in a spare water neck.
Hole size for 3/8 - 18NPT is 9/16".
Old Apr 20, 2010 | 10:08 PM
72LS1Vette's Avatar
72LS1Vette
any suggestions?
Buy a thermostat housing for a 79 Corvette at AutoZone. It has 2 holes tapped into it - 1 can be used for a heater hose and 1 can be used for a temp sensor. I'm working from memory here but I was able to plug in a temp sensor for an electric fan into a 79 thermostat housing and run a heater hose also. If that is not correct there is defnitely a way to use that housing for a temp sensor.
Rick B.
Old Apr 20, 2010 | 10:30 PM
terrible_buddhist
Rick B.
I think you are on to something here...
http://www.autopartswarehouse.com/de...1&apwidrm7D5F9
To where do I stick this thing?
