68 vette build sheet location
Old Apr 21, 2010 | 12:21 AM
68blueshark's Avatar
68blueshark
Default 68 vette build sheet location
Hello
I bought a 68 vette 2 years ago and it had a new gas tank. Well I would guess that there is no build sheet on the new gas tank.
Is there a second location that chevy placed a copy of the build sheet in the car?
Someone told me that under one of the seats there would be a copy of the build sheet. Any truth to that? Any other location for the build sheet?
Ed
Old Apr 21, 2010 | 12:27 AM
jordan89's Avatar
jordan89
It can be under the carpet of one of the seats, or behind the gauges on the steering column I think they said could also be a spot.
Old Apr 21, 2010 | 08:10 AM
CFD E59's Avatar
CFD E59
Found mine behind the tach gauge..Loosen the center gauge cluster and gently pull it towards you, the you should be able to see behind their. I don't rec'd reaching under dash, vac lines could come loose and if it is there you don't want to rip it removing it.
To 68 vette build sheet location
