mini starter pinion depth
Old Apr 23, 2010 | 07:19 AM
Acid 67's Avatar
Acid 67
Default mini starter pinion depth
my starter doesnt work right.
the gear from the starter only works on the half gear from the flywheel.
it seems that the starter shaft is to short.
with shims there is nothing you can do.
where is the problem??
Old Apr 23, 2010 | 11:48 AM
Shark Racer's Avatar
Shark Racer
Do you have the wrong starter for your application?
153 tooth or 168 tooth flywheel?
Old Apr 23, 2010 | 12:05 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Half tooth engagement is OK I had less than 1/4 tooth and never installed the starter, I think it is because I have a lightweight flywheel and they have to take metal off somewhere. You can't shim the tooth depth only the distance between the gears
To mini starter pinion depth
