383 stroker $ idea
Old Apr 23, 2010 | 08:35 AM
samuk's Avatar
samuk
Default 383 stroker $ idea
I have been offered the following setup, just build, new.
Needed an idea of value of such engine setup in US....
See the Video now:
http://www.youtube.com/watch?v=mZppRv7eia4
- 350 block four mains
- 383 eagle stroker kit with forged JE pistons;
- Trick flow head 23 dg, 195cc intake, 62 chmaber and double spring;
- Comp cam 1.75 roller rocker
- CompCam camshaft 288X278 112 LOB
- Comp cam pushrods high energy
- Crower solid lifters
- Compcam Valve cover
- Felpro gaskets
- ARP complete bolt set
- Melling HP/HV pump
- Moroso 383 sump HV
- Fluid damper wheel
- Edelbrok HV water pump
- Edelbrok Victor EFI Intake
- Air Gap
- Holley EFI 1000 CMF/ 82lbs/h injectors
- Magnafuel pressure regulator
- Magnafuel fuel pump
- Lakewood tremec bellhousing
- Melling timing chain
- High power clutch set
Old Apr 23, 2010 | 09:36 AM
gkull's Avatar
gkull
Probably under $6000. I don't think that it is a well though out project. The compression might be to high with 62 cc heads. I am not a solid lifter fan and then they use an odd rocker ratio only used in racing motors. I use 1.7 to get big valve lift in my 434 ci roller cammed small block.
It also has a gear driven cam that kids use to make the motor whine like it has a supercharger or something.
The heads are questionable as to performance.
The holley injection is a $2000 item.
Old Apr 23, 2010 | 09:51 AM
samuk's Avatar
samuk
engine is runnig puer ethanol, hence the high compression
Old Apr 23, 2010 | 11:50 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Are you building a race motor and or max performance street/strip motor ?
Either way those heads suck, if you already bought them sell them unless you are building a street cruiser
Old Apr 23, 2010 | 02:59 PM
samuk's Avatar
samuk
The engine was offered as part of an old settlement deal. I need a street cruiser, not a strip racer. Can this setup be adapted to a good cruiser/power setup?. What would you change on this?.
Old Apr 23, 2010 | 07:47 PM
MotorHead's Avatar
MotorHead
Should be fine, the rockers are too high a ratio, 1.6 max.
Old Apr 23, 2010 | 07:57 PM
JGreen's Avatar
JGreen
What's wrong with these heads? I was considering these for my 75 (no racing, just cruising)?
Old Apr 23, 2010 | 07:59 PM
Gordonm's Avatar
Gordonm
Get rid of the gear drive setup. Sell the heads for a better set. Run a set of 1.6 rockers. I ran solid cams for years and recently put in a roller cam. If you have the cash go for a roller. Hyd or solid roller.
Old Apr 24, 2010 | 07:28 AM
samuk's Avatar
samuk
Pics and Video added
Old Apr 26, 2010 | 10:33 AM
gkull's Avatar
gkull
This motor is more for somebody that understands lots of things mechanical. I personnally have stayed away from Fuel injection until these aftermarket kits get it right. I don't have the time to tinker and hook up a lap top or some other device to make air fuel ratio/spark changes. The solid lifter cam assumes that you know how to adjust the valves periodically.
I would wonder about why they would be running a motor with the blower not even hooked up?
If you are willing to adjust the valves. I would drop the rocker arm ratio down to 1.6 and ask if you could just have a simple holley 650 or 750 CFM carb.
Old Apr 26, 2010 | 11:47 AM
MotorHead's Avatar
MotorHead
There are better heads out their for the same price, Mustang guys love them but do a poll here and won't find too many
If you already have them, then they are fine for a street cruiser
Old Apr 26, 2010 | 02:42 PM
10caipirinhas's Avatar
10caipirinhas
Toss the rocker arms, EFI and gear drive........or just buy one of these.......by the time you are done it's probably the same price.
http://www.golenengineservice.com/sp...383_500tk.html
To 383 stroker $ idea
