timing question
Old Apr 23, 2010 | 06:46 PM
1nicecorvette's Avatar
1nicecorvette
Default timing question
i just got done doing the intake gaskets. i removed the dizzy (not doing the number one cylinder trick) but instead marking it. I have the car running 100% better and smoother then ever before but. my dizzy is turned farther to the left then it looks like it should be. vac advance is at or around 8 o'clock position used to be 6:45 area before install.
so my question is. when i get it in for the timing to be adjusted will they be able to line up the dizzy housing so its straight again?
Old Apr 23, 2010 | 06:52 PM
Gordonm's Avatar
Gordonm
Yes. You can put the dist in any position you want as long as the wires are in the proper location. It sounds like you are off one tooth or so. Easily reclocked.
