Matching numbers or Modified Value
Any comments on values, depreciation, etc.
just in a cross road between going complete restoration to original or modified - tend to modify but do not want to screw with car value - and again its a corvette, and there will always be a lover for it.
other guys actually drive it, and really enjoy it, run the socks off that cat....IF you want to actually enjoy the car, enjoy the chance encounters with other folks, enjoy talking cars you have a fun/fine opportunity to do so....
If you don't enjoy working on cars, there is no particular point to having a old car of any type.....and if you do, you may well have a creative streak that will push your imagination into changing a few things, that is where the camel nose gets in the tent....
it obviously starts with wheels and tires, as any old rubber is trash and can't be safely used....so if you want decent tires, you have to change the wheels....so if you want improvements there you maybe do the suspension....brakes are poor on a good day, so upgrades there too....power steering is well antiquated, suspension rides like a truck, you get the drift.....
then most sharks had like <300 hp not even 10 lbs/hp ratio....
then if you do any freeway driving you need overdrive....
if you appreciate modern FI technology, you put that on....
before you know it, you got MY car.....
worth far more than any stock vette of similar years....why? because it actually has VALUE, not something occupying space in a garage, gathering dust while the owner suffers some delusion of grandeur
" what's the difference in value of a car you can drive, and one you cannot?"
"something you can enjoy as it was intended to be, or something you can only, longingly, look at?
Sorry, but I fail to see the desire to own a museum piece, or a car that's identical to so many others.
Nothing like a quality custom to turn heads....
All this does is inflate the price of a car some real car guy wants but can't afford anymore. Ever see the prices for 69 Camaros or Chevelles and most are fake with SS badges glued on them
Steve
Steve
If its an auto '76 model mod away and who really cares
Some of us did not have the luxury of making that decision as the original motors on most of these 40 yr old cars is long gone
BTW, I chuckle when I see "date correct" block..........blah, blah, blah. All that means is someone sourced a block from another vehicle built during the same time
That's why I went the retro route, an original 68 SB auto, so what right? BUT I have all the original stuff, including the engine. It only had 386,425.1 miles on it.
