Headlight Actuator Question
Old Apr 24, 2010 | 04:59 PM
mconwayjr's Avatar
mconwayjr
Default Headlight Actuator Question
I'm sure this has been asked before but when I tried searching this topic but got 25 pages of results. After I couldn't find my answer on the first page of results I figured it would be easier to ask.
Is there a way to test the diaphram on the actuators?
My lights were not going up or down. I tested everything with my might vac and have identified two issues.
1. Vacumm canister was not holding vacuum due to a crack. I made a temporary repair just so I could get the canisiter to hold vacuum. I will be ordering a new one of these.
2. Faulty Actuator. My boots and seals are trashed. Before I order those, I wanted to verify that the diaphram is still good. I would hate to order the rebuild kit to find out that the actuator needed replacement anyhow.
Any insight is appreciated.
Thx.
Marshall
Old Apr 24, 2010 | 05:06 PM
...Roger...'s Avatar
...Roger...
Test the side without the seal and that will tell you if the diaphragm is good.
Old Apr 24, 2010 | 05:10 PM
mconwayjr's Avatar
mconwayjr
Awesome, thx Roger. They hold a vacuum just fine. I appreciate the help.
Marshall
To Headlight Actuator Question
