Help! Brakes pull and rear suspension issues
First issue is the brakes. The car pulls HARD to the right when applying the brakes. I've bled the brakes and get fluid from all the bleeder valves, but it still pulls just as bad as before I replaced the leaking front calipers.
The second issue is with the rear suspension. The car sags. The left side is lower than the right side. I figured the problem was likely the worn out spring bushings, but I replaced those and adjusted the ride height. Both sides are out of adjustment and it still sits 3/4" lower on the one side.
This might be of help. Look at how badly out of alignment the rear end is:
The camber adjustment on the ride side was already pretty much maxed out so I couldn't get past -2.0 degrees, and I didn't mess with toe adjustment since it looks like you have to unbolt the rear trailing arm? Anyways I need to find out why it's out of spec and why it sits lower on the left instead of trying to correct it with an alignment.
Thanks for any suggestions,
Jesse
The sag on the LH is pretty common. You could try adjusting it out, but more than likely you need new springs front and rear.
